Solid alloy mounts
  • chopper
    • Nov 2002
    • 167
    • scotland
    nice work on both sets of mounts guys
    mick
    xs1.1s(x2)
    gsxr1100(1127)
    gsx1100g(x2)
    trophy900
    bonneville750
    http://www.tonyfoale.com/
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      If I was to use poly bushings I would use a sleeve similar to our shock mounts. Most poly bushing for suspension use have these sleeves. I used to sell 4 x 4 parts.
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
      • mason79
        • Mar 2006
        • 1359
        • los angeles, ca
        there a pruduct the used for vintage mustang suspensions, from global west, i think it's called derin white and hard as heck on the durometer, may not need a sleeve.
        History
        85 Yamaha FJ 1100
        79 yamaha xs1100f
        03 honda cbr 600 f4
        91 yamaha fzr 600
        84 yamaha fj 1100
        82 yamaha seca 750
        87 yamaha fazer
        86 yamaha maxim x
        82 yamaha vision
        78 yamaha rd 400
        • 79XS11F
          • 3563
          • Ottawa, Ont. Canada
          Re: poly
          Originally posted by xschop
          I saw those too (very nice work). I made a rear bottom set (solid)for my latest project to keep the sprocket steady in relation to the frame. Question, why didn't you extend the poly all the way to the end of the inner metal mount?
          The Poly part likely matches the engines mount point width. No real sense in having the extra doing nothing ... right.
          Rob
          KEEP THE RUBBER SIDE DOWN
          1978 XS1100E Modified
          1978 XS500E
          1979 XS1100F Restored
          1981 Suzuki GS1100
          1983 Suzuki GS750S Katana
          1983 Honda CB900 Custom
          • Brian_D
            • 355
            • Gardner, KS
            TC,
            will this get added to the CUSTOM PARTS/SERVICES By MEMBERS sticky in the Buy, Sell, Trade Forumn?
            Chop,
            will pm soon. want 1 set for my 79F project bike. after that is running, will want a 2nd set for my 81LH.
            • concours
              • Mar 2007
              • 43
              • Kensington, NH USA
              Originally posted by HobbyMan
              Why did yamaha use rubber to begin with?
              VIBRATION ISOLATION....... I'm changing my '05 Royal Star over to rubber mounts FROM alloy bushings....
              • xschop
                • Feb 2006
                • 1794
                • oklahoma city
                2 words
                v-twin......our xs11's won't vibrate you to death....the solid mounts will stiffen up the xs11's frame and the big difference is when you are throttling it in a corner....I thought the fork brace was a great improvement, then I added a set of these....
                MDRNF
                79F.....Not Stock
                • concours
                  • Mar 2007
                  • 43
                  Re: 2 words
                  LOL, it's a VEE-FOUR. (descendant of the V-max/Venture) and it is very smooth. ALL engines buzz some and my worn out old wrists can't take it.
                  What fork brace do you have? Christopher Chassis Products made a nice chrome molly one. I had them ladder up my swing arm too.
                  • xschop
                    • Feb 2006
                    • 1794
                    • oklahoma city
                    sorry
                    my goof, I rode a vmax couple months ago and it wasn't as smooth as the xs11, but it was definitly smoother than a v-twin....
                    MDRNF
                    79F.....Not Stock
                    • AlanB
                      • Oct 2006
                      • 705
                      • Scotland
                      Hi XSchop,
                      I started with a set of pre-made suspension bushes for a car, which already had the correct inside and outside diameters, so the length was already set. I only thinned the "brim" part of the top-hat bush.
                      If I could have found the right material I would have made the bushes the same length as the mounts.
                      However, they work well!
                      AlanB
                      If it ain't broke, modify it!
                        Hey Alan,
                        I was going to ask you to give us the type of car, but then realized you're "over there", our luck would be some exotic make/model we don't have over here anyways!?
                        • AlanB
                          • Oct 2006
                          • 705
                          • Scotland
                          Hi T.C.
                          The bushes are made by "Powerflex". They do a big range of Specific Fit bushes, But the ones I used were from their range of "Universals" designed to be modded for unusual vehicles. They go up in (I think) 2mm steps, and come with an overlength (60mm?) centre bush.
                          So they are not meant for anything specific!
                          The centre bushes were made up by a local engineer, and the Poly bushes got the "brim" thinned a little. I also upped the size of the bolts which hold the front mounts to the frame from 8mm to 10.
                          AlanB
                          • xschop
                            • Feb 2006
                            • 1794
                            • oklahoma city
                            material
                            these will be made from t6061 and have a tolerance +3- thousanths...just sent these out to 79XS11F....will ship these (t6061) anywhere in U.S. for $75 and need 10 days lead time...just PM me....chop
                            MDRNF
                            79F.....Not Stock
                            • 79XS11F
                              • 3563
                              WOW ... I received my solid alloy engine mounts yesterday and I must tell you ... Theses babies are NICE and very well made.
                              Thanks a bunch Xchop
                              Rob
                              1978 XS500E
                              1981 Suzuki GS1100
                              • TomB
                                • 967
                                • Cumbria, UK
                                Another reason for not extending the rubber the full length of the inner bush is coz the tube spacer has locating pieces tacked on that locate over the inner bush.
                                We use rock hard plastics where I work (pharmaceutical industry) and have to constantly re-torque the bolts down on it because it creeps like crazy. I really would recommend using steel insert bushes.
                                Tom
                                Tom
