I rode to OKC today and inspected Chop's XS750 final drive transplant.
It appears to be "kosher" and is really not much more than a bolt on deal. I rode his bike about 15 miles today and can say without hesitation ...IT WORKS!
The bike did launch a little sluggish...but then it should with much taller gearing. However it wasn't like launching the bike in second gear.
But at 70 mph on the highway the Eleven was very relaxed...about like it normally would be at 60 mph.
The only catch is the drive shaft difference between the 1100 shaft and the 750 shaft. This can be made to work with a 5/8 collar or if you are like me (perfectionist nut) you can have a machinist lengthen your OEM 1100 shaft about 3/4 inch.
This is no doubt the path I'll take. But I am convinced it will be worth the effort. Using standard gear reduction calculations Zilla should be revving about 4400 rpm at 80 mph!!! That's a reduction of 600 rpm from my stock setup.
As a matter of fact the final drive ratio will be almost identical to that of my ZRX1200R. I have no idea why Yamaha originally geared these old Elevens so low. I suppose to get the 1/4 mile time down.
I'll post some photos as this modification take's place.
Don't ask...
