Evapo-Rust (Rust Remover) - A 100% thumbs up
    • 8009
    I found that a 5 gallon pail of Metal Rescue is available from Summit Racing for $86.00. I have not seen a better price. Does the electrolysis method work any better than the rust chemicals?
    I don't believe the electrolysis method works better than Metal Rescue. It is a lot cheaper, but more labor intensive.
    My tank had rust covering the entire inside of it. I knew I was going to replace the liner with the Caswell epoxy. I removed the rust with phosphoric acid. I filled the tank with water and add two cups of straight acid to it. Overnight, the rust was completely eliminated. I rinsed it with baking soda in solution, dried it and put the liner in it. Acid will take off metal. Metal Rescue will not.
    Here is the pdf for doing a motorcycle tank with Metal Rescue.
    Metal Rescue™ Motorcycle Gas Tank De-Rusting Tips
    BTW, some Home Depot stores carry Metal Rescue. Maybe you can pick it up close to home. Summit is all the way down in McDonough.
    • MPittma100
      • Aug 2011
      • 2359
      Metal Rescueâ„¢ Motorcycle Gas Tank De-Rusting Tips
      So, your saying that the Metal Rescue and the phosphoric acid remove rust equally, but the Metal Rescue is less intrusive?
      Mike
      1981 XS1100H Venturer
      K&N Air Filter
      ACCT
      Custom Paint by Deitz
      Geezer Rectifier/Regulator
      Stebel Nautilus Horn
      EBC Front Rotors
      Limie Accent Moves On In 2015
      Mike
        • 8009
        Mike
        Yes. If I were considering not lining the tank. Metal Rescue is the answer. If I'm sure I'm going to line it, phosphoric acid will save me some $$.
        • MPittma100
          • Aug 2011
          • 2359
          Tank Repair
          Marty,
          What was the deciding factor for you as to whether or not to use the epoxy liner? Also, for future reference, where did you get the phosphoric acid?
          Thanks, Mike
          K&N Air Filter
          ACCT
          EBC Front Rotors
          Mike
            • 8009
            Marty,
            Thanks, Mike
            What decided it for me was that the inside of the tank was completely rusted. I assumed it would come back in a hurry. I picked up the phosphoric acid at The Home Depot.
            • CKlamer
              • Oct 2013
              • 117
              • Huntsville, AL.
              #66
              Metal Rescue has another product that you can spray on or coat with lik the inside of my tank I just poured some in and moved the tank around until I thought it was completely coated.
              It's suppose to keep what you treat from rusting for a full year. So before use I will throw a little gas in the tank and swish it around and it will neutralize the product.
              It's called DRY COAT RUST PREVENTATIVE.
              79 YAMAHA XS1100F
              2012 KAWASAKI CONCOURS
              1981 HONDA CB985CR
              • MPittma100
                • Aug 2011
                • 2359
                Dry Coat
                Yes, I saw that advertised by Metal Rescue and will likely use it as well.
                K&N Air Filter
                ACCT
                EBC Front Rotors
                Mike
                • MPittma100
                  • Aug 2011
                  • 2359
                  Progress Report
                  I have completed a second Acetone treatment to my tank. It got out this time what I believe to be all that it is going to get. It does look much cleaner. I will use the abrasive media (stones) next. After that treatment, I will decide which rust removal method to use. Then it will be time to determine whether to install a liner or not.
                  Mike
                  K&N Air Filter
                  ACCT
                  EBC Front Rotors
                  Mike
