Evapo-Rust (Rust Remover) - A 100% thumbs up
  • rs2289
    • Oct 2012
    • 18
    • Drums, PA
    This stuff works AWESOME! and it is reusable to boot!
    79 SF "Under Construction and in a million pieces"
    • LoHo
      • Sep 2002
      • 1342
      • Fresno, CA
      Would it be feasible to pour EvapoRust in the bottom of a plastic storage bin to use as a dip tank over and over? Does it evaporate or dry out?
      • KA1J
        • 664
        • Groton, CT
        You can do that and the company encourages re-use but you might want to filter out particulate matter. Yes, it does evaporate.
        i also asked if I could dilute it with something, perhaps water to allow a slower process but with a larger volume of mass to deal with, like filling a gas tank with the dilute solution and waiting days for it to act. The answer was do not dilute it, leave it concentrated and turn the tank, shaking it every so often to cover all parts.
        It works beautifully.
        • Shacknasty
          • Feb 2011
          • 379
          • SFV-SoCal
          There is a thicker, gel-like, Evaporust that I've only seen sold in quart cans. It can be applied with a brush. Turns green as it works. I think it would work fine on exhaust pipes.
          • andylawcc
            • Dec 2012
            • 49
            • Los Angeles, CA.
            so if I use "Evapo-Rust" or Metal Rescue, i won't have to use Phosphoric Acid or Muriatic acid in this article?
            and if so, do i still need to rinse it with baking soda + water, and then once more with acetone/alcohol? (i reckon i still need the latter part right? to get rid all the evapo-rust chemical...)
            79 XS11
              Directions say to rinse with water, dry and apply a rust inhibitor. For a fuel tank I would rinse with water, then denatured alchohol to remove the moisture.
                • 8079
                If you use Evaporust or Metal Rescue, DO NOT follow with acid. Since you don't use acid, there is no need to follow with baking soda to neutralize it. Follow the instructions on the bottle. You may have to rinse it with water. Follow the instructions to avoid flash rust.
                If following with a tank liner, I would rinse with lacquer thinner and then line it.
                • Shacknasty
                  • Feb 2011
                  • 379
                  • SFV-SoCal
                  If yer gonna line that tank, stay away from Kreem! Use POR-15 or RedKote or just go to a radiator shop and have them line it.
                  • andylawcc
                    • Dec 2012
                    • 49
                    • Los Angeles, CA.
                    ack, i don't have denatured alcohol, and that gas tank sealer stuff ain't cheap too. i guess i will let the pros at a radiator shop do it instead.
                    okay, i thought Evaporust / Metal Rescue is some kind of acid too.
                    79 XS11
                      • 8079
                      Nope. It's not acid.
                      • Brent
                        • 959
                        I have had good luck with Caswell"s epoxy. Much less prep work.
                        Brent in GA
                        • Courtney
                          • 542
                          • Nanaimo BC Canada
                          Pictures of evaporust at work
                          Here are some time lapsed photos of Evaporust - hope this works.
                          Original rust.
                          Bone stock 1980 Special except for the exhaust and crashbars. Oh yeah, and the scabbard for the Winchester Defender.
                          • Courtney
                            • 542
                            • Nanaimo BC Canada
                            After 2 hours.
                            • Courtney
                              • 542
                              • Nanaimo BC Canada
                              After 24 hours.
                              • Shacknasty
                                • Feb 2011
                                • 379
                                • SFV-SoCal
                                Good pics. Rustoleum should send you a check!
