KZ750B Twin Snow Bike Sidecar
    My winter daily driver needed some work in the shop. Originally, I purchased this bike in 2013 with a seized motor for $50.00 at a tag sale. I poured Marvel Mystery oil in the cylinders and a month later the motor was free. Cleaned the carbs, fork seals, cables, battery ect. I have put 50,000 on it since then. I have ridden through pouring rain, blistering heat, and several New England blizzards to get to work.
    Click image for larger version  Name:	DSCN3932.JPG Views:	0 Size:	202.1 KB ID:	877201 Click image for larger version  Name:	tim.JPG Views:	0 Size:	30.4 KB ID:	877202 Click image for larger version  Name:	image1 (1).jpg Views:	0 Size:	130.2 KB ID:	877203 Click image for larger version  Name:	IMG_0225.jpg Views:	0 Size:	160.9 KB ID:	877204
    This is when I brought it home with a seized motor.
ID:	877206 Click image for larger version
ID:	877207 Click image for larger version
ID:	877208 Click image for larger version
ID:	877209 Click image for larger version
      Then I found a Velorex sidecar in Springfield MA.
ID:	877212 Click image for larger version
ID:	877213 Click image for larger version
ID:	877214 Click image for larger version
        I rebuilt everything. Countless hours of labor put in. But now I could ride year round. Literally every day. And I could carry a lot of cargo. I added a Dnepr military fairing & Vetter Hippo Hands for weather protection.
ID:	877218 Click image for larger version
Name:	KZB Snow 1.jpg
ID:	877219 Click image for larger version
ID:	877220 Click image for larger version
ID:	877221 Click image for larger version
          As the years went by, I had many great times on that bike. 50,000 miles of fun & practical transportation.
ID:	877224 Click image for larger version
ID:	877225 Click image for larger version
ID:	877226 Click image for larger version
ID:	877227 Click image for larger version
            So after 50,000 miles it needed some work. Many parts worn and wire harness ruined by salt damage.
            Click image for larger version  Name:	DSCN7787.JPG Views:	0 Size:	187.8 KB ID:	877230 Click image for larger version  Name:	DSCN7794.JPG Views:	0 Size:	200.0 KB ID:	877231 Click image for larger version  Name:	DSCN7795.JPG Views:	0 Size:	198.4 KB ID:	877232 Click image for larger version  Name:	DSCN7799.JPG Views:	0 Size:	180.2 KB ID:	877233 Click image for larger version  Name:	DSCN7800.JPG Views:	0 Size:	179.4 KB ID:	877234
              But still, it got me through another winter.
ID:	877236 Click image for larger version
ID:	877237 Click image for larger version
ID:	877238 Click image for larger version
ID:	877239 Click image for larger version
                But now the work begins. The sidecar frame became quite corroded despite my frequent washes during the winter at the local car-wash. It had to be disassembled, sand-blasted, and new swing arm bearing installed.
ID:	877242 Click image for larger version
ID:	877244 Click image for larger version
ID:	877243 Click image for larger version
                  Lots of salt damage to the electrical system. Hand wired the entire bike. I used multi conductor trailer cable. I have been using a Gammatronix universal electronic ignition. My points are only used as a switch closure. No heavy current runs through them. The contacts last virtually forever. I have been running this for several years now in all kinds of weather.
ID:	877248 Click image for larger version
ID:	877249 Click image for larger version
ID:	877250 Click image for larger version
ID:	877251 Click image for larger version
                    I have also eliminated the two wire single phase alternator charging system. With countless hours of research I have discovered you can run a 3 phase KZ1000J stator and regulator from a police bike. About 3 times the charging power. All Rick's Electrics quality stuff.
ID:	877254 Click image for larger version
ID:	877255 Click image for larger version
                      Fork rebuilding & steering head bearings.
ID:	877258 Click image for larger version
                        • 2074
                        Excellent-My late Father used to say a motorcycle is not a year end vehicle-you proved otherwise!!
                          New front sidecar mount. Much stronger than universal clamps.
ID:	877263 Click image for larger version
ID:	877264 Click image for larger version
ID:	877265 Click image for larger version
ID:	877266 Click image for larger version
                            Engine work. Lap valves & new Viton seals.
ID:	877269 Click image for larger version
ID:	877270 Click image for larger version
                              New Vesrah metal head gasket. Cam re-install. Careful timing procedure. Torque head 30ft LBS.
ID:	877273 Click image for larger version
ID:	877274 Click image for larger version
ID:	877275 Click image for larger version
ID:	877276 Click image for larger version
