750 Virago
  • LuckyEddie
    • 166
    • Middleville, Michigan
    I missed this post when it came up. I too have a 82 750 Virago. I used the J-clip from the Chopper Bob kit and things work much better. Great bike!
    Two more sites for info are: www.viragoownersclub.org and www.drpiston.com
    LuckyEddie
    1980 XS1100LG Midnight special
    1982 XV750J Virago
    1976 GL1000
    1978 GL1000 Supercharged
    1981 XV920RH (chain drive)
    • tarzan
      • 1700
      • Chandler,Az.
      I had the #2 idler gear and the flywheel machined by Dr. Virago pete.Then installed a 4 brush starter.It started well.Once in a while it would make a little noise.
      I tore the bike completely down last winter to go through and paint a bring everything back into shape and havent got back to it yet.
      80 SG XS1100
      14 Victory Cross Country
        Starter blues
        I forget the details so you gotta go dig yourselves.
        Sign up with the YAM650 site in micapeak.
        Bill Denton the YAM650 list owner did a good write-up on Virago starters detailing the different starters used over the years and in different countries and what the best way is to fix them. The write-up is in the YAM650 archives which are not the easiest to dig in, but you are motivated, right?
        • rpgoerlich
          • Dec 2007
          • 643
          • Katy, Tx
          #34
          Yamaha still sells the New tension clips and the shims for the #2 idler gear. You could replace the gear with the updated one that has the different profile on the end that engages the flywheel, kinda pricey though, $90.
          Other problem with the gear is that it has a rubber cushon molded to it. If it detoriates it moves it even farther away from the flywheel. It can be flipped in a pinch, once the bad side is cleaned off. Just need to add shims to make up the difference.
          I did the profile trimming on #2 gear with a dremel with new clips and shims for an XV700 I had. Box a rocks sound went away as it never missed engaging.
          Richard
          • TONIO
            • 60
            • HOUSTON TEXAS
            #35
            Tarzan
            be patient with virago tech they will be able to help you with that model I had one and they got me going once your in the site.
            It will be a like atmosphere as the xs 1100 they are also very helpfull.
            Tonio
            tonio
            81 xs eleven special
