I keep hearing about the lack of charging power on these XS11's and I was wondering how many of you were seriously interested in more output from the alternator? I have a friend who's business is rebuilding alternators and we have discussed the possibilities and how to increase the output. I'm thinking of doing something about mine and I was wondering how much interest there was in such a modification among the XS's.
More power!!!!
More power!!!!
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake linesTags: None -
This is me XSpressing interest
Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example"Comment
Planedick,
I've toyed with the idea of increasing the number of windings on the field coil, there's enough room there to get 10-15 percent more turns on it. That would boost the output a bit. Just haven't got my hands on a spare alternator to try it out.Comment
"We are often so caught up in our destination that we forget to appreciate the journey." "Comment
are you hinting at something, there, Winterhawk?
'81 XS1100 SH
Sep. 12th 2015
RIPComment
More turns...
Just adding more turns won't work. In addition to more turns you also need to increase the wire size or the extra amperage will make the wire too hot and short out. I'm also working on an oil pressure guage, amp guage, and remote idle adjust.You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Stainless braid brake linesComment
Re: oil pressure guage
I have an oil pressure gauge on my E. I use the electronic gauge, not the mechanical one (with the plastic hose). I installed a "T" fitting where the stock sender is behind the cylinders. Then I reinstalled the sender for the stock idiot light on one side of the "T" and the sender for the new gauge on the other side. In my case I wired it into the fairing harness so If I run the bike with no fairing I still have the stock light.Originally posted by mro
Wouldn't mind having one for my 80G and LG
Gauge could save an engine
mroPat Kelly
Guages
I was thinking of making a bracket to mount on top of the instrument group attached with hot melt glue to hold the amp guage and the oil pressure guage, maybe with a light inside them.....You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
