More power!!!!
  • planedick
    • Mar 2005
    • 2068
    • Yorba Linda, California
    More power!!!!
    I keep hearing about the lack of charging power on these XS11's and I was wondering how many of you were seriously interested in more output from the alternator? I have a friend who's business is rebuilding alternators and we have discussed the possibilities and how to increase the output. I'm thinking of doing something about mine and I was wondering how much interest there was in such a modification among the XS's.
    Drilled airbox
    Tkat fork brace
    Hardly mufflers
    late model carbs
    Newer style fuses
    Oil pressure guage
    Custom security system
    Stainless braid brake lines
  • webbcraft2150
    • Sep 2002
    • 1605
    • AUSTIN.TX
    Ay, Scotty, I need more power!!!!
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      This is me XSpressing interest
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
      • randy
        • Dec 2003
        • 4521
        Planedick,
        I've toyed with the idea of increasing the number of windings on the field coil, there's enough room there to get 10-15 percent more turns on it. That would boost the output a bit. Just haven't got my hands on a spare alternator to try it out.
        • woodbutcher
          • Jun 2005
          • 33
          • Mora Mn.
          yah suure it would be nice
          woodbutcher
            • 7821
            I can always use more power!! and I can get you a spare alt. for the practice! Let me know via pm.
            Ray
            • pathfinder
              XStremely XSive(Deceased)
              • Apr 2004
              • 483
              • Houston, TX
              Me too, never enough.
              There's always a way, figure it out.
              78XS11E
              • randy
                • Dec 2003
                • 4521
                OK, guys.
                I PM'ed Diverray and if he sends me a spare field coil, I'll wind it up and test it on Swamp Thing in a couple of weeks. I'll post photos and results here.
                Let's hope this works!
                Just what I need, another project
                • Winterhawk
                  • Jun 2004
                  • 684
                  • Missouri
                  Honda, Yamaha, Kawasaki, Suzuki, voltage, regulator, rectifier, cb750, cb900, cb1000, cb1100
                  • 81xsproject
                    • 3185
                    • Fortuna, CA
                    are you hinting at something, there, Winterhawk?
                    '81 XS1100 SH
                    Sep. 12th 2015
                    RIP
                    • planedick
                      • Mar 2005
                      • 2068
                      More turns...
                      Just adding more turns won't work. In addition to more turns you also need to increase the wire size or the extra amperage will make the wire too hot and short out. I'm also working on an oil pressure guage, amp guage, and remote idle adjust.
                      Drilled airbox
                      Tkat fork brace
                      Hardly mufflers
                      late model carbs
                      Newer style fuses
                      Oil pressure guage
                      • mro
                        • Oct 2005
                        • 4276
                        • Hayward, California
                        oil pressure guage
                        Wouldn't mind having one for my 80G and LG
                        Gauge could save an engine
                        mro
                        • Pat Kelly
                          • 3046
                          • Golden Valley, AZ
                          Re: oil pressure guage
                          mro
                          I have an oil pressure gauge on my E. I use the electronic gauge, not the mechanical one (with the plastic hose). I installed a "T" fitting where the stock sender is behind the cylinders. Then I reinstalled the sender for the stock idiot light on one side of the "T" and the sender for the new gauge on the other side. In my case I wired it into the fairing harness so If I run the bike with no fairing I still have the stock light.
                          Pat Kelly
                          • planedick
                            • Mar 2005
                            • 2068
                            Guages
                            I was thinking of making a bracket to mount on top of the instrument group attached with hot melt glue to hold the amp guage and the oil pressure guage, maybe with a light inside them.....
                            Drilled airbox
                            Tkat fork brace
                            Hardly mufflers
                            late model carbs
                            Newer style fuses
                            Oil pressure guage
