LenB, I'm glad it worked out for you.
Squealing Brakes
The XS650 from 1977 on has the same caliper as the standard XS11. Shop for XS650 shims if you don’t want to make them. The should be cheaper than XS11 parts.Marty (in Mississippi)
XS650EComment
80 GComment
Squealing coming back after I put the shims in. (many,many bad words). What would happen if I took the glaze off the rotors with a wire wheel? Has anyone tried this or would it just cause faster pad wear? There's a kit available at MikesXS that replaces all the other metal bits surrounding the pads: https://www.mikesxs.net/yamaha-xs650...045-02-00.html - might try those. Looked up shims for a 77 XS650 and they want to sell you a kit (pads/shims/clips) only.(lower part group #15) Maybe I'll just bite the bullet and get 2 of those.
1980 XS1100G (one owner-me)
1984 Honda VF750S V45
Owned - 1976 XS750D
Owned - 1972 Honda CB750
Owned - (unknown year) XS650
(+ too many Yammies/Hondas to mention)Comment
XS650EComment
XS650EComment
That's a good point about the pads themselves. There are all sorts of brake compounds such a sintered, Kevlar, ceramic and organic. Perhaps the pad material could be changed to something that does not resonate as much. I think organic brake pads are considered the quietest and do the least damage to the rotors. Sintered can be harsh to rotors and probably squeak the most.
Find many great new & used options and get the best deals for Front + Rear Organic Brake Pads 1978-1981 Yamaha XS1100 Set Full Kit E F G H xf at the best online prices at eBay! Free shipping for many products!
Deebs11 - thanks for the link - I kinda knew it was too good to be true - read down the page and got "Does not ship to Canada". (lots of very bad words) I'ii try and source north of the 49th.1980 XS1100G (one owner-me)
Owned - 1976 XS750D
Just to add, I've used 80 grit on a sanding disk with a cross hatch pattern, that also seems to help. Sometimes it will last, sometimes not.Last edited by bikerphil; 10-19-2023, 05:45 PM.2H7 (79) owned since '89
☮Comment
bikerphil - only applied grease on the side contacting the puck. Quick tear-down and I'll be a little more liberal with it. Been looking into organic or semi-sintered pads - found some EBC FA34 organic units available on Amazon.
At over $40 a set not cheap. Made in the UK - any thoughts from across the pond?
DEEBS11 - Dennis Kirk doesn't have enough semi-sintered or organic on hand right now (might as well replace all 3 sets) - but thanks for the info anyway.
Owned - 1976 XS750D
It probably does not matter what country you are getting them from. My guess is almost all of them are made in China anyway. I try to stay with the organic pads on my XS1100's. The newer bikes, sintered or ceramic pads as they are designed for them.Ray Matteis
