VIN & Exchangeable parts
  • Hawkinspickle
    • Feb 2022
    • 82
    • British Columbia Canada
    Hi folks,
    I'm new to the forum and new to older Yamaha's. Happy to be here. Just bought a 1979 XS1100, …I think. I say I think because my registration papers say it’s a ‘78 but what I’ve read on line I think it’s the ‘79 special as I noted above. I can’t seem to decode the 9 digit VIN. My VIN is 3H4-000721. Can anyone please confirm my findings?
    Also, I am looking to buy some headers and exhaust on eBay but they are from a 78. Does any know if the 78s and 79s exchange this part or most others? Thanks.
    Dan.
  • LenB
    • Nov 2020
    • 160
    • Winnipeg, Manitoba, Canada
    Check out https://xs11.club/forum/miscellaneou...identification 3H4 shows up as a Canadian '79 Special. Majority of parts, from my experience, are common from '78 to '81, based on the model (Special/Standard). This can be verified by checking out any seller's parts fiche. e.g. https://www.yamahapartshouse.com/oem...-xs1100f-parts and comparing part #'s vs. production years.
    1980 XS1100G (one owner-me)
    1984 Honda VF750S V45
    Owned - 1976 XS750D
    Owned - 1972 Honda CB750
    Owned - (unknown year) XS650
      • 735
      Welcome to the forum Dan,
      Here's a lot of great info from Crazy Steve regarding exhaust interchange:
      Interchange Guide: Exhausts, Footpegs - XS11.club Forums
      Good luck,
      Bob
        • 7828
        Welcome! Some of the body parts, seat, side covers, grab bar, are ONE year only! You have an early VIN, so it was probably sold late '78, and registered as a '78 and not the '79 model it is. Do check with andreas, a member here who breaks bikes and knows the XS1100 well. He is located in Canada, just north of the Idaho border. I know from experience that you cannot put a standard exhaust on a special without some mods. Most aftermarket exhaust, however, will fit either machine.
        • Hawkinspickle
          • Feb 2022
          • 82
          Thanks everyone for the information and the excellent resources. Never belonged to an online club before but always creeped various public forum discussions and found them to be very helpful. I can now say that I am the owner of a 1979 XS1100SF; thanks Len.
          I just got outbid by a guy on eBay on some headers and aftermarket exhaust. But after reading some the info provided by you folks, maybe it was a good thing as they may not have fit my bike. My apologies if it was of you guys who I was bidding against and drove up the price a few bucks.
          I have tons to learn about these bikes but motivated to do so cause they’re super cool.
          Dan
            • 8074
            The XS1100SF parts fiche is no longer available. That's the 1979 Special. It has differences from the 80/81 Specials.
            • Hawkinspickle
              • Feb 2022
              • 82
              A quick glance at the fiche detials, in particular the rear fender, the forks and the cross-over on the exhaust, I see that these are different from my bike which is a '79 special.
              • Hawkinspickle
                • Feb 2022
                • 82
                Hi folks,
                Just confirming, would an engine from a 1980 Yamaha XS1100S (serial number 3U9-000640) bolt into my 1979 XS1100SF (3H4-000721) without issue? A very good source in this group told me that it including the electrical would work without modifications. Not wishing to second guess my friend, I just wanted to be sure before I pull the trigger on the engine purchase.
                Thanks,
                Dan
                • red bandit
                  • 970
                  • central michigan
                  The engine from a 80 will swap right in a 79 frame. Not sure if the 80 ignition will work with the 79 ignition but you can swap the 79 ignition on to the 80 engine.
                  79 SF parts bike.
                  • Hawkinspickle
                    • Feb 2022
                    • 82
                    Thanks for confirming. After searching around, I found a post on this site that says the change to the ignition was in '81, just like my friend said it would. So I'm good to go.
                    • Hawkinspickle
                      • Feb 2022
                      • 82
                      Another silly question folks: while I assume that the carbs from my '79 special will bolt with no problems to the '80 special engine, I understand that the XS11's were de-tuned a bit in the 80s. Was this "de-tuning' to meet higher emission standards done to the engine or was it done to the carbs? I guess I am wondering what I will experience, if anything, with the swap from '79 engine to the '80?
                      Dan
                        • 7828
                        Carbs should bolt up and work, after a vacuum sync. Later carbs had a few changes, but a carb is a carb, and they all try to flow the same amount of air with the XS1100's.
                        • Hawkinspickle
                          • Feb 2022
                          • 82
                          Thanks Ray.
                          • Rasputin
                            • 3193
                            • Lacombe, Alberta, Canada
                            I have them here if anyone needs. I did send them all to TC but he disappeared shortly after. I wanted to share all the parts fiches and manuals with the group. I guess he never did the link to them.
                            2-79 XS1100 SF
                            2-78 XS1100 E Best bike Ever
                              • 7828
                              You may be able to upload the fitch as a pdf. If so, post it in the forum/maintenance/tools section. It should then be available to everyone.
