Boorrrringggg Build/Rebuild/Refres&restore
  • Wildkat
    XS Special Gurette
    • Apr 2004
    • 3416
    • Location, Location
    #121
    I wasn't laughing at you.
    It's just a relief knowing I'm not the only that stuff happens to...
    81 SH Something Special
    79 SF MEAUQABEAUXS
    81SH Nor'eas tah (Old Red)
    80 LG Black Magic
    78 E Standard Practice
    James 3:17
    “Alis Volat Propriis”
    Yamaha XS 1100 Classic
    For those on FB
    • puskrat
      • Jun 2015
      • 312
      • Peoria IL
      #122
      Oh I wasn't offended. I'm about the most self-deprecating person you'll find. Sorry if I stirred anything.
      "Venturered" 80 XS1100G - "DoraMax" getting sort of resto/destro ed.
      Yeah it's a pretty blue, but just because you're old is no excuse to buy a bagger. Fortunately I have wrenches.
      • Wildkat
        XS Special Gurette
        • Apr 2004
        • 3416
        #123
        Pfffffft
        I'm just getting the popcorn ready for your next installment.
        Best of luck!
        79 SF MEAUQABEAUXS
        80 LG Black Magic
        James 3:17
        For those on FB
        • puskrat
          • Jun 2015
          • 312
          • Peoria IL
          #124
          Best of luck!
          mmm hmm
          geekingtomeetlengthrequirement
          • puskrat
            • Jun 2015
            • 312
            • Peoria IL
            #125
            I did a thread to find out about bolts/machine screws, and another one to vent about the petcocks. I have yet to get frustrated enough with the rebuild to switch to non - vacuum valves. I have a feeling I will.
              I don't blame you for venting but don't give up. There are no OEM vacuum diaphragm kits for the Standard fuel taps, just the rubber gaskets, o-rings, seals and screws and they're more than a little expensive. They're not as expensive as changing the engine or rebuilding it after you fill the oil pan with fuel but yeah, they're expensive:-
              http://www.partzilla.com/parts/searc...ANK/parts.html
              (Left-hand side)
              15 GASKET 1J7-24512-00-00 $26.86 $17.98
              16 VALVE 1J7-24523-00-00 $9.89
              17 SEAL, COCK 1J7-24534-00-00 $22.56 $15.18
              (right-hand side)
              29 GASKET 1J7-24512-00-00 $26.86 $17.98
              30 VALVE 1J7-24523-00-00 $9.89
              31 SEAL, COCK 1J7-24534-00-00 $22.56 $15.18
              $43.05 per side, $86.01 for the three main rubber parts on both sides and you still haven't touched the assortment of screws, sealing washers and other hardware you may need after you take everything apart.
              If you get bored there is a good tutorial with pictures on the xjbikes.com site about rebuilding the fuel taps and vacuum valves. I think chacal has the parts to rebuild the vacuum valves on the XS11 Standards but the ones in my '80G are still working so I haven't checked:-
              http://xjbikes.com/forums/threads/re...-w-pics.25058/
              FWIW Yamaha still lists the complete vacuum valve assembly for the 'Specials and the XJ11 but it's expensive too. I like the octy so I ordered a new one instead of fooling with any of the half-fast aftermarket kits and then still dumping fuel all over everything after doing a bunch of work.
              http://www.boats.net/parts/search/Ya...ING/parts.html
              39 DIAPHRAGM ASSEMBLY 3H3-24520-01-00 $94.48
              I'll see if it's really available in a timely manner, not stored in that Yamaha warehouse they have out on Jupiter and will have to be shipped sunward on the next available comet heading for Earth.
              • ViperRon
                • Feb 2011
                • 1062
                • Woodstock, VA
                #127
                I have a 1980 G and got Suddco kits from MikesXS and had no problems with them working but there are things you have to pay attention to when rebuilding there are several threads that have picture tutorials. The main issues are that the plunger goes in and seals correctly and then does not stick. If the plunger is too corroded to where cleaning and mild polishing can not clean it or the orifice it goes into can not be polished to where the O ring seals it will leak gas. If the spring is severely corroded it will not work properly. There is a vent that must be cleaned and all ports should be cleaned. The internal seal that seals the ports must mate against the back of the assembly and the outside rotatable cock valve must be polished to assure a smooth fit it can be sanded with fine paper and then polished. The wafer washer must be put in correctly and there must be unbinding movement of the valve. To test you can put a hose on the vacuum and lightly suck to test it opens port. Put fluid in a bottle with a hose coming out attached to the gas port to test flow and leaks backwards I know but still tests function. Assembly with a little fine smear of grease just rubbed on seal can help with the cock valve seal . Do it right look at the videos and you can get it done if you really want to its no more complicated than changing a tire correctly.
                Rodan
                1980 G Silverbird
                1198 Overbore kit
                Grizzly 660 ACCT
                Barnett Clutch Springs
                R1 Clutch Fiber Plates
                122.5 Main Jets
                ACCT Mod
                Mac 4-2 Flare Tips
                Antivibe Bar ends
                Rear trunk add-on
                  No, it's not particularly difficult to rebuild and maintain the Standard taps but you do have to be careful or you'll rip the vacuum diaphragm(s). I don't want an engine full of fuel so I try as much as possible not to mess with them and I won't use aftermarket parts in them: many horror stories and few success stories. I do keep them clean and lubricated but other than that I just leave them alone except during maintenance.
                  Mine still have the vacuum diaphragms that were in them when I bought the bike back in 2008 and they were probably the original parts. I finally had to add new vacuum valve o-rings and replaced the other rubber fuel parts last month when I was trying to put Columbo together because they were on their third or fourth time around. You can only flip the cookie-cutter gaskets and massage the fuel tap handle v-rings so many times before they won't work any more, darn those worthless parts that only last 36 years!
                  The o-ring seats for the vacuum valves do have to be clean and polished and then kept that way, they're not making any more of them.
                  • puskrat
                    • Jun 2015
                    • 312
                    • Peoria IL
                    #129
                    Oil filter retainer
                    The original scope of the project included R/R of the rounded oil filter bolt. While my petock work is still in progress, it's nevertheless time for the torching and wrenching. I'm pulling exhaust headers to provide clearance. Four retention nuts off, to be replaced with stainless (what thread are they anyway?)
                    Header number Two is loose, and Three pulled completely off, but I finger there's a clamp at the end of each header I have to conquer.
                    • puskrat
                      • Jun 2015
                      • 312
                      • Peoria IL
                      #130
                      pairs. Four PAIRS of nuts off. eight
                      • puskrat
                        • Jun 2015
                        • 312
                        • Peoria IL
                        #131
                        Uhoh
                        Well then. I left the motorcycle unattended for about thirty minutes, and I see a pan of oil under it, some splashes around said pan, and a filter, housing and o-ring sitting near my exhaust nuts.
                        Body Shop mgr tells me my filter was oil was full of gas but the crankcase was clean as brand new. Repeats it twice. Still seems surprised that I am not (surprised). then he shows me the filter housing. The nut welded to the filter bolt appears to be welded to the housing as well. I'm thinking this is not a standard feature. This is the first time I've had mine off. When i took posession the bolt was rounded off. Now the whole rig looks like a spinon filter. With a removable element. Do I need to get ahold of Andreas and take that filter housing off his hands?
                          Got a picture?
                          Here's an example of normal oil filter bolts:
                          Partzilla.com
                          Oil Filter Bolt
                          Price:$12.86
                          List Price $15.95
                          You Save $3.09 (19%)
                          Quantity: 1
                          Be careful if you buy an aftermarket bolt. I haven't had it happen to me personally but in some of them the bypass valves have stuck.
                            #133
                            Here's the best photo I could find showing the engine bottom and at the top is most of the oem filter cup.
                            The bolt is Steel, but the cup is aluminum, so it should have been difficult if next to impossible to weld the nut to the housing along with the actual steel filter bolt head.
                            Yep, some photos of what you have would be nice to see.
                            • puskrat
                              • Jun 2015
                              • 312
                              • Peoria IL
                              #134
                              The newly manufacturered filter housing assembly.
                              LOOKING FOR SOMETHING TO ACCOUNT FOR THE ATTACHMENT.
                              LOOKING INSIDE FOR SOMETHING TO SPLEEN THE NEW FUSION
                              THE NEW NUT IS WELDED TO THE OLD ROUNDED HEAD, NOT TO THE HOUSING.
                              WHAT AM I MISSING HERE? (besides the ability to use a website?)
                              Last edited by puskrat; 09-30-2016, 03:33 PM. Reason: UGH....GOTTA BE SMARTER THAN THE WEBSITE
                                Unless someone broke or ground off the locator tabs on the housing I didn't think it was possible to tighten or remove the oil filter if the bolt wouldn't turn in the housing. Hmm....
                                It's not likely the bolt's welded to the cup but you never know. I'm pretty sure the oil filter bolt threads are pipe threads so if it will fit, put a pipe coupler on the threaded end of the oil filter bolt to protect the threads,
                                Heat the aluminum cup with a torch or heat gun, then spray some of that compressed air in a can on the bolt to chill it. Just hit the bolt, not the aluminum housing or you'll have to start over.
                                Set the filter housing on a couple of boards to protect the fins. Keep the bolt head between the boards and make sure it's well above the table.
                                Rap the bolt/pipe coupler with a rawhide mallet or a large chunk 'o wood and see if that will drive the bolt down and out. Stop if it really doesn't move or if the bolt starts to drop so you don't try to drive it through the table.
                                If it's not pipe threads, be a little more circumspect and tap around the body of the bolt with a hammer and wooden dowel. Try to work it back and forth to loosen it, then work it down and out.
                                You could also try flipping it so the bolt threads are on a board, then put an oversized socket or pipe over the entire bolt and try to tap the housing down and off the shoulder of the bolt.
