Boorrrringggg Build/Rebuild/Refres&restore
  • puskrat
    replied
    OKAY VICTIMS. Back at it. My employer has decided he can no longer afford to keep me around, no more cars than he's selling. As such, I removed myself from my place of employment. After about a month of searching, I found a trailer to haul dora home. Shes b een living in the dealership body shop parts overflow shed during the work chronicled here. Fortunately my unemployment days do not (hopefully) coincide with high cost restoration work. I think I'm looking at setting valve clearances, maybe replacing a bent valve (go bent valve club) and hopefully no further diagnoses.
    Leave a comment:
  • puskrat
    replied
    I'm thinking of some responses. They are in poor taste.
    Leave a comment:
  • puskrat
    replied
    Well I was kind of bent over the whole business, truth be told. Ah well....
    Leave a comment:
    replied
    BVC meeting
    Hi, My name is T.C., and I haven't been on a "BENDER" for 17 years. I keep my bent valve on the workbench to remind me not to get bent ever again! :P
    Leave a comment:
    replied
    Welcome to the Bent Valve Club! Replacing valves isn't difficult, just annoying.
    We don't have meetings but do commiserate as needed: you have my heartfelt commiserations.
    Leave a comment:
  • puskrat
    replied
    Thanks for the Boldface, 3phase. I'm askeert I may have a problem in there....I did have resistance. Couldnt overcome it. That's why I popped the starter.
    I false alarmed on the clearance check/shim change, and really dont know when i will actually be able to get in there. Now I guess I'm looking for a bent valve. joy.
    Leave a comment:
    replied
    Be careful with that axe, Eugene
    Originally posted by puskrat
    Before things start turning at a rate measurable in revolutions per minute, I want to triplequadruple overthink everything. Andy's cam chain adjuster video says there should be a distinct snapping sound when the tensioner is released. There was not. Should I be concerned?
    I don't remember where I saw it but one way to set the tensioner is to put the bike on the center stand and rotate the crankshaft clockwise to the "C" mark.
    Remove the tensioner from the engine and look at the marks on the plunger from the set screw to see if there is enough adjustment left in the tensioner or if it's time to get a new cam chain.
    DO! NOT! EVEN! THINK! ABOUT! TOUCHING! THE! CRANKSHAFT!
    Check the little rubber coated metal seal/cup in the tensioner's nose and change it or reseal it so it won't leak.
    Push the tensioner plunger all the way back in its housing, then lightly lock it in place with the set screw.
    Put the tensioner back on the engine with a new gasket and torque the bolts to 86.4 in-lb (7.2 ft-lb or 10Nm / 1.0 m-kg) .
    Release the set screw and you should hear the click as the plunger extends and hits the front cam chain guide.
    Tighten the tensioner set screw to 51.6 in-lb (4.3 ft-lb or 6 Nm / 0.6 m-kg)
    Tighten the locknut to 78 in-lb ( 6.5 ft-lb or 9 Nm / 0.9 m-kg)
    NOW! you can think about touching the crankshaft and rotate it clockwise by hand a few times to make sure the cam chain didn't slip while you had the tensioner out of the engine.
    Stop! if you feel any resistance at all, that'll be a piston touching a valve. It's easier to turn the crank if you remove the spark plugs but it's not absolutely necessary.
    Leave a comment:
  • puskrat
    replied
    Leave a comment:
  • puskrat
    replied
    Woohoo. On a day off (from the paying job) I fingered out I have the parts necessary to get a headlamp into my bucket and on my bike. Slight celebration last night when it all came together. Just have to trace electricity for it. I've forced my schedule to comply, and will be valving tonight. period.
    Leave a comment:
  • puskrat
    replied
    Nothing wrong with the Venturer seat. Very comfortable as is.
    Pitt, lemme tell ya. They say there's a seat for every butt and a butt
    for every seat. I'm not sure which one is odd in this case (me or it, not me or you), but I'm not feelin the same affection for the Venturer seat as yourself.
    Leave a comment:
  • MPittma100
    replied
    Ventured Seat
    Leave a comment:
    replied
    puskrat, I just passed on that info. to ya' cause I still have my Venturer seat off my Venturer, in the closet, still new just like it came off bike when I bought bike new. I've had the Corbin seat for that model on my Venturer now for more yrs. than I can remember(CRS).
    Leave a comment:
    replied
    Do what I'm doing on my concours, 6mm closed cell neoprene and then 1.5" medium closed cell foam. Neoprene base, 1" medium, 2mm neoprene, 1/2" medium. Then shape with an electric carving knife, 1/4" open cell foam and cover.
    Sit on the seat while working on it so you don't go too high for your inseam, or too hard for your a$$. It should be a little cushy but firm, and with the closed cell it will not absorb water.
    Leave a comment:
  • puskrat
    replied
    Thanks, Ray. Am really surprised at the condition of the foam on this piece. I guess I shouldn't be, at only 18,000 MI of course Ive had the seat off since the whole proper process but I don't remember what I saw. I have a holster maker standing by to cut me a new cover, but don't know what to do about foam. I think Gel would be a better solution the old stuff.
    Leave a comment:
    replied
    Okay here's the deal....still dodging life to try to get the valve shyte done. Meanwhile I'm using my 'chained to desk' time for some design work. Said design work is focused on selecting a seat and developing a mounting system.
    This is Dora....
    What the heck is that seat? The bike is a 1980 Standard (G), and I see the bags and fairing are Venturer equipment-1981. Is that where the seat came from also? Ive been thinking it might be a midnight. The seat is too thick, too wide, and too seventies. It's like sitting on a horse and both my legs are malformed after a few minutes pushing the effer around from storage to work location etc. My vision is to put on a solo seat and a Quick Release second solo seat. After Ive done that I'll have to adjust pegs and/or install floorboards and consider alternate controls. Maybe I'll run a Mustang replacement of some kind, but at any rate I have to get this couch off my motorcycle.
    FYI that IS a Venturer seat.
    Leave a comment:
