Just having what you stated in post #57 and post #58 as a bases, tells me there's initially resistance from battery source to fuse panel supply, somewhere.That's obviously not good......should be the same as at battery.
IIRC, previously you said the headlite comes on with key on, doesn't have to be triggered on from START mode. If still assuming that is correct, then there would be a LITTLE voltage drop when that circuit is complete with fuse insertion along with tail lite fuction.
Know this may sound mundane to you, but do you have access to a batt. load tester? A wet cell batt. may SHOW acceptable voltage(12.7-13.1v) across the post under NO load, but be lower than normally acceptable with load.
Case in point(since I no longer have access to good carbon=pile load tester), our Ford Escape's Interstate batt. showed 12.8v across post, no load.
Turn key on, that became 4v
, with an obvious 'no start' situation.
Immediately, that indicates at minimum, 4 shorted cells!
Not sure what brand or load rating your batt. is, but a safe 220-240amp. load should tell you if it will hold a steady 10.5v under THAT load, for at least 30seconds. If voltage drops below that during that load test, that battery is comdemmed as failing, or very soon tottally fail!
That CAN be the source of the problem, low idle voltage and all the other things goin on voltage related.
Point being, checking the voltage source with a simple load test, and not just assumming since batt. shows acceptable voltage across post, that it is 'good' will at least eliminate it as being questionable.
This sort of thing has bit me in the arse more than I care to remember
, ( with a shop foreman making me feel pretty stupid for not conducting a complete protocall test).
JAT Greg, and IMHO, would be the proper starting point.
, with an obvious 'no start' situation.Immediately, that indicates at minimum, 4 shorted cells!
, ( with a shop foreman making me feel pretty stupid for not conducting a complete protocall test).JAT Greg, and IMHO, would be the proper starting point.
(Sold back to Maximan)
