XS1100 Standard for $1.00
  • #16
    Originally posted by TheRev View Post
    He said once he got married his wife wouldn't let him ride so his bike has been sitting in his mother's garage for 16 years.
    My wife is great and I love her, but she knows if ever she gave me the ultimatum "its me or the bike" I'd help her pack
    Its great that he let you have it, and that you're putting another XS1100 back where it should be, OTR.
    Tom
    • #17
      Thanks for all the great comments. I am a current rider. I have a Honda Shadow that I cruise around in. I am not an aggressive rider by any means. We have great country and scenic roads where I live so I enjoy the twisties and hills. The XS is a little heavier than I am used to but that shouldn't be a problem.
      I hope to have the bike done by the spring. I guess it just depends on finances. I have a new fuseblock to install. Topcat I believe I bought one from you a couple of months ago. I also have an original air box that I will be using rather than the cheap pods.
      My wife isn't to thrilled about motorcycles but she likes that I have a hobby as long as it doesn't cost too much money and the parts aren't in our living room. So I simply don't tell her how much it costs and I moved the parts to the family room. All is well
      1979 xs1100f
      New Fuse Box
      Progressive Shocks
      Gold Valve Emulator
      Dyna Coils
      Electronic Flasher
      Led Headlight
      Led Turn Signals
      4 Led Driving Lights
      2nd Gear Fix
      Auto Cam Tensioner
      Digital Dash
      Stainless Braided Lines
      R6 4 Piston Calipers
      Stainless Bolt Kit
      Maier Fairing
      Dyna Balancing Beads
      Spin On Oil Filter
      Stebel Nautilus Horn
      Plasti Dip Rims
      ISO Grips
      • #18
        Originally posted by CRXSi90 View Post
        It's looking like it's coming along nicely. Are you going to have it ready for the Slimy Crud Run in the spring?
        I would love to make that run this spring. Do you know the dates. Perhaps I can make that my goal. I believe the Crud Run begins less than two miles from my place.
        1979 xs1100f
        New Fuse Box
        Progressive Shocks
        Gold Valve Emulator
        Dyna Coils
        Electronic Flasher
        Led Headlight
        Led Turn Signals
        2nd Gear Fix
        Auto Cam Tensioner
        Digital Dash
        Stainless Bolt Kit
        Maier Fairing
        Spin On Oil Filter
        Plasti Dip Rims
        ISO Grips
        • #19
          That sounds like a great plan. I'll give you the link for the Slimey Crud Run dates. I'm about 7 miles away from the starting point, just inside the beltline.
          http://www.slimeycrudrun.com/when/
          It's the 1st Sunday of May and October, so it looks like for 2013, it's....
          Sunday, May 5th, 2013
          Sunday, October 6th, 2013
          Did you buy marine vinyl for your seat yet? My $0.02 is to glue all the foam pieces together, add a layer of batting, then go ahead and put together a vinyl cover to fit. Does the misses have a sewing machine that you can use?
          '81 XS11H Venturer - holed up in storage while life happened since 07/08/04
          '81 Kawasaki KE175 enduro - 63 mph of smokey fun, now with collector plates!
          • #20
            Just to add a further tip if you are going to recover the seat yourself. Use a heat gun when stretching the vinyl. It fits better when it's heated.
            Wayne
            80 XS1100 SG "Phoenix"
            "We are the type of band that if we moved in next door to you...Your lawn would die"
            Lemmy from Motorhead
            • #21
              Looks like another XS found a good home! Yer doing a helluva job so far. Keep up the good work and keep posting progress reports and pics, por favor hombre.
              A flap disc on an angle grinder will do a great job of smoothing out the foam, followed by a little hand sanding and it'll look a lot better. Don't give up on it yet. Like CRX says, a little batting will work wonders.
              • #22
                I thought I would post what the engine looks like now. I currently have it on a stand in my garage. Thanks to a thread I found on this site called (lo- buck Engine Stand) I was able to make brackets and modify a car engine stand. I am going to take the top off the engine and adjust the valves. I am also planing on painting it black.
                1979 xs1100f
                New Fuse Box
                Progressive Shocks
                Gold Valve Emulator
                Dyna Coils
                Electronic Flasher
                Led Headlight
                Led Turn Signals
                2nd Gear Fix
                Auto Cam Tensioner
                Digital Dash
                Stainless Bolt Kit
                Maier Fairing
                Spin On Oil Filter
                Plasti Dip Rims
                ISO Grips
                • #23
                  Today I picked up my exhaust pipes and headers from the ceramic coater. They look awesome. The guy used Cerakote Black Velvet. Apperently that stuff comes in an air dry formula. They sure look good. I just took some pics, however the pics don't really show how pretty they really are. The pipes were still cold from being out in my car so they look kind of gray in the photos. Anyhow, I can't wait to start to put this thing together. I hope I remember how it goes.
                  Remember, the pipes are cold and that is why they look gray. They are actually black with a velvet look to them. I am very pleased.
                  1979 xs1100f
                  New Fuse Box
                  Progressive Shocks
                  Gold Valve Emulator
                  Dyna Coils
                  Electronic Flasher
                  Led Headlight
                  Led Turn Signals
                  2nd Gear Fix
                  Auto Cam Tensioner
                  Digital Dash
                  Stainless Bolt Kit
                  Maier Fairing
                  Spin On Oil Filter
                  Plasti Dip Rims
                  ISO Grips
                  • #24
                    Look very nice. Keep up the good work!
                    • #25
                      Originally posted by TopCatGr58 View Post
                      Hey there Rev,
                      Great pictures and story. I know the OEM fuseblock looks pretty decent, but those GLASS FUSES are a real weak spot, along with the flimsy brass spring clips, and it's really suggested to replace it with the ATCO style fuseblock and fuses. I resell them for COST which just covers the expenses incurred by me getting them and then resending them out,ie paypal, shipping, etc.!
                      The Pod filters look like the cheap EMGO brand, see the tech tips...MODS, carbs, regarding pod filters and velocity stacks. There was a recent thread regarding same concerns regarding performance with PODS vs. the OEM airbox and such.
                      Check out the LED conversion tips for turn signals and running/brake lights and such. Our bikes have self cancelling signals, there are ways to preserve that feature with LED signals, some don't bother and just install a 2 prong electronic flasher and just turn the signals off themselves.
                      Folks will want to see your R6 caliper mod progress! keep up the good work, you'll have a fine ride when you're done for sure.
                      Also, just have to say you haven't said anything about any prior riding experience?? If it's been years/decades since riding, we recommend taking the MSF course.
                      TopCat
                      Do you know where you saw a thread about LED signals that allows the self canceling feature to work?
                      1979 xs1100f
                      New Fuse Box
                      Progressive Shocks
                      Gold Valve Emulator
                      Dyna Coils
                      Electronic Flasher
                      Led Headlight
                      Led Turn Signals
                      2nd Gear Fix
                      Auto Cam Tensioner
                      Digital Dash
                      Stainless Bolt Kit
                      Maier Fairing
                      Spin On Oil Filter
                      Plasti Dip Rims
                      ISO Grips
                      • #26
                        Tech tip here: http://www.xs11.com/forum/showthread.php?t=34406
                        • #27
                          Thanks crazysteve. Now I just have to figure out what it all means and how to put it together.
                          1979 xs1100f
                          New Fuse Box
                          Progressive Shocks
                          Gold Valve Emulator
                          Dyna Coils
                          Electronic Flasher
                          Led Headlight
                          Led Turn Signals
                          2nd Gear Fix
                          Auto Cam Tensioner
                          Digital Dash
                          Stainless Bolt Kit
                          Maier Fairing
                          Spin On Oil Filter
                          Plasti Dip Rims
                          ISO Grips
                          • #28
                            Coming along great! As TC mentioned, its a great idea to swap out that fuse box. Mine literally melted down shortly after I ordered but had not yet installed the nice one he sells. its very easy to put in and takes the common spade fuses.
                            Nate
                            78 XS11 "Matilda" 2H7 000364
                            K+N Air Filter
                            88 Voyager XII
                            81 XJ650 Maxim
                            • #29
                              I just added the new fuse box yesterday. I was reading some posts. It looks like catatonicBug replaced his rectifier and regulator. Is that something I should look into?
                              1979 xs1100f
                              New Fuse Box
                              Progressive Shocks
                              Gold Valve Emulator
                              Dyna Coils
                              Electronic Flasher
                              Led Headlight
                              Led Turn Signals
                              2nd Gear Fix
                              Auto Cam Tensioner
                              Digital Dash
                              Stainless Bolt Kit
                              Maier Fairing
                              Spin On Oil Filter
                              Plasti Dip Rims
                              ISO Grips
                              • #30
                                We don't have a sewing machine. It sounds like your close. What year bike do you have? Have you done any mods to your bike?
                                1979 xs1100f
                                New Fuse Box
                                Progressive Shocks
                                Gold Valve Emulator
                                Dyna Coils
                                Electronic Flasher
                                Led Headlight
                                Led Turn Signals
                                2nd Gear Fix
                                Auto Cam Tensioner
                                Digital Dash
                                Stainless Bolt Kit
                                Maier Fairing
                                Spin On Oil Filter
                                Plasti Dip Rims
                                ISO Grips
