Google it , I think its a ceramic coating and they do them inside too, check out the pics on their site, sorry I don't have a link the exhaust is supposed to run 300f cooler and you gain 1-3 percent hp
Reason: addition
Me and the wiz just picked my new ll we stopped by the local car wash and gave it a good douche , man it cleaned up nicer than I expected now for the fun stuff
If you buy the polishing rougues and assorted pads
to fit a dremel/drill, and good quality paint stripper
it makes life all the easier.
pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
After further inspection only the side covers and valve cover have much corrosion , the engine and jugs look to be in fair shape. Any way just got finished dumping the oil and putting some mmo in the cylinders also while the oil plug was out and filter cup I spun the motor with the kick start to pump everything out, next I need to figure out where the drain plug for the middle drive is? Where is my darn manual! Next thing is sorting out a set of carbs , the set that came on it are friggin rusted shut. Also looks like the petcock seem to be gummed up, I need to get the tank cleaned and maybe some seafoam will help with that, thankfully no visable rust in the tank but the whole thing stinks of turpentine
My 9 days of vacation are done and I have to work today but I don't go in till 3 tomorrow so I should be able to wrench for a little bit , I guess ill drain the middle and final drives and dump the gas tank and pull the petcocks , are the seals reusable for those or do they have to be replaced , I am going to make a shopping list!
Yeah I found my shop book an located it , when I first looked at the bike it seemed to be a little far from the middle drive but according to the book that's it!
so all fluids are drained and I am just waiting on parts to get this one fired up(I hope) contemplating the brakes and hoping the rebuild kits for my mc arrive soon ,as well as newer carbs I still have to install the new carb boots and fuel ,vacuum lines and a battery and oh yeah oil. and we'll see if she fires!
