evil twin!!
  • foreda
    • 949
    • Southwest Louisiana
    Jet hot??
    Fill me in on this Jet Hot stuff? I've heard of it but that's about it???
    78 XS1100E Standard
    Coca Cola Red
    Hooker Headers
    1979 XS1100 Special
    1980 XS Standard
    2006 Roadstar Warrior
    • GARTHXS
      • 1631
      • Seattle
      jet hot
      Google it , I think its a ceramic coating and they do them inside too, check out the pics on their site, sorry I don't have a link the exhaust is supposed to run 300f cooler and you gain 1-3 percent hp
      91 kwaka kz1000p
      Stock
      ( Insert clever quote here )
      • GARTHXS
        • 1631
        • Seattle
        its here
        Me and the wiz just picked my new ll we stopped by the local car wash and gave it a good douche , man it cleaned up nicer than I expected now for the fun stuff
        91 kwaka kz1000p
        Stock
        • petejw
          • 2269
          • sydney australia
          #34
          engine polishing
          hi Garth,
          Ive been polishing the engine up on mine
          heres a link
          If you buy the polishing rougues and assorted pads
          to fit a dremel/drill, and good quality paint stripper
          it makes life all the easier.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          1981 xs1100 RH (aus) (5N5)
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • Stralya
            • Apr 2006
            • 791
            • 'Blotto Grotto' Wodonga, Victoria, Australia.
            #35
            My polishing effort
            I did this on my Dad's bench grinder fitted with a polishing pad and three grades of rouge.
            Before
            After
            Took about 20 minutes. I have a dremel tool but I can't imagine where I'd even begin to get results like you Pete.
            For the dullards, the polished bit is the handlebar clamp.
            Dan.
            Shine on.
            Automotive Imbecile.
            Proud owner of 'The Swiftcicle'. (Swifty for short)
            '78E Full Vetter Dresser.
            1196 Big Bore Kit.
            • GARTHXS
              • 1631
              • Seattle
              #36
              sounds good
              After further inspection only the side covers and valve cover have much corrosion , the engine and jugs look to be in fair shape. Any way just got finished dumping the oil and putting some mmo in the cylinders also while the oil plug was out and filter cup I spun the motor with the kick start to pump everything out, next I need to figure out where the drain plug for the middle drive is? Where is my darn manual! Next thing is sorting out a set of carbs , the set that came on it are friggin rusted shut. Also looks like the petcock seem to be gummed up, I need to get the tank cleaned and maybe some seafoam will help with that, thankfully no visable rust in the tank but the whole thing stinks of turpentine
              91 kwaka kz1000p
              Stock
              • GARTHXS
                • 1631
                • Seattle
                #37
                back to work
                My 9 days of vacation are done and I have to work today but I don't go in till 3 tomorrow so I should be able to wrench for a little bit , I guess ill drain the middle and final drives and dump the gas tank and pull the petcocks , are the seals reusable for those or do they have to be replaced , I am going to make a shopping list!
                91 kwaka kz1000p
                Stock
                  #38
                  Hey Garth,
                  I just pulled my petcocks and reused the seals with no problems. But my bike was not as mistreated as yours.
                  • GARTHXS
                    • 1631
                    • Seattle
                    #39
                    I will see
                    If that. Works tomorrow will wd40 take off paint?
                    91 kwaka kz1000p
                    Stock
                      • 6765
                      #40
                      middle gear drive drain plug
                      IIRC it should be underneath the engine towards the back edge...you'll see a drain bolt...HTH
                      2005 Honda SilverWing 600
                      2018 Honda PC-Xpress 150
                      • GARTHXS
                        • 1631
                        • Seattle
                        #41
                        thanks
                        Yeah I found my shop book an located it , when I first looked at the bike it seemed to be a little far from the middle drive but according to the book that's it!
                        91 kwaka kz1000p
                        Stock
                          • 6765
                          #42
                          Yup...BTDT
                          • GARTHXS
                            • 1631
                            • Seattle
                            #43
                            drained
                            so all fluids are drained and I am just waiting on parts to get this one fired up(I hope) contemplating the brakes and hoping the rebuild kits for my mc arrive soon ,as well as newer carbs I still have to install the new carb boots and fuel ,vacuum lines and a battery and oh yeah oil. and we'll see if she fires!
                            91 kwaka kz1000p
                            Stock
