Seafoam in the spark plug hole
  • Montreux_Blue
    XS-XJ Guru (Deceased)
    • 1143
    • Longitude: -85ยฐ 57' 43" Latitude: 37ยฐ 52' 55"
    I'm just guessing, no scientific testing to back me up.
    Famous Myspace quote:
    • Axel
      • May 2007
      • 869
      • Renfrew,Ontario
      Thin oil worries
      I put in a full can onto the cylinders . About half a quart . Thats how much my oil has risen . Thats quite a bit more than is recommended ( about 1/2 to 1 ounce) . So my car takes about 4+ quarts of oil ...
      I hope I dont do engine damage if I drive it gently a couple of miles
      XJ1100K
      Avon rubber
      MikesXS black coils
      Iridium plugs w/ 1k caps
      MikesXS front master
      Loud Horns (Stebel/Fiamm)
      Progressive fork springs
      CIBIE headlight reflector
      YICS Eliminator
      • planedick
        • Mar 2005
        • 2068
        • Yorba Linda, California
        Too much
        Way too much for driving, likely spin a bearing and maybe even score a crank.......
        Drilled airbox
        Tkat fork brace
        Hardly mufflers
        late model carbs
        Newer style fuses
        Oil pressure guage
        Custom security system
        Stainless braid brake lines
        • Axel
          • May 2007
          • 869
          • Renfrew,Ontario
          or not
          Kool - I'll change the oil myself where it sits . I think I can still run it a bit standing still with the thin oil to clean the crankcase .
          What do you think ?
          XJ1100K
          Avon rubber
          MikesXS black coils
          YICS Eliminator
          • Axel
            • May 2007
            • 869
            • Renfrew,Ontario
            further on
            With advice from a friend ,I took out the plugs cranked the engine with a rag over the holes until I had pressure . There was quite a bit of Seafoam still in one cylinder especially. It made a bit of a mess but didnt want to bend any parts if the volume of liquid in the cylinder exceeded the compressable limit . I then replaced the plugs and it started right up - but smokey!!! It was so bad I idled the car up the street as my neighbours were beginning to wonder. After 10 or so minutes I idled it back to the garage . At this point it didnt sound too lubricated . I changed the oil and filter.
            It runs better ,less vibration and more zip . Remains to be seen if it stops burning oil .
            XJ1100K
            Avon rubber
            MikesXS black coils
            YICS Eliminator
