Seafoam in the spark plug hole
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    Tonight I had an idea . My car(Toyota Corolla) burns oil and research points to the oil seal piston ring carboned up . So I poured about 114 ml(1/4 can) of seafoam in each cylinder to soak as long as possible . I was thinking of cranking it over occasiaonally with out the plug wires attached ( once a day) .
    Anybody ever try this ?
    My bike burns some oil . Do you think I should try this on the bike ?
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
  • powerram50
    • 92
    • portland,oregon
    change the oil after....
    81 SH for 300 bucks,work in progress.
    87 dodge d-50,35's,lockers fr&rr,fun.
    87 dodge d-50,35's,open diffs,wifes.
    89 dodge spirit,low 17's 1/4mile w/o turbo.
      • 8077
      My car had that problem. The drain holes under the oil rings were clogged and the rings were stuck. I replaced the rings and worked the head. It runs like new!
      I guess what you're doing can't hurt, but I'll be surprised if it works. It's certainly worth a try.
      • Crazcnuk
        • 2980
        • Hinton, AB, Canada
        I had a 650 Midnight Maxim, that seemed to run fine.
        One day I did a compression test for the heck of it and all 4 cylinders were 95-100psi.
        Put (not seafoam, but hey) diesel on top the pistons, let it sit overnight and changed the oil the next afternoon.
        Compression was 135-140psi across the board, and I found out what it was SUPPOSEd to run like...
        '05 ST1300
        • TADracer
          • 1417
          • Kenner, Louisiana USA
          I agree with changing the oil after and you have to make sure you do not score the cylinder walls on startup since the Seafoam has probably taken all the lubrication away. You might consider turning the motor over until you get oil pressure before you start up.
          Mike Giroir
          79 XS-1100 Special
          • jeffe
            • Oct 2004
            • 393
            • Westerville,Ohio
            Take at look at this video. It tells all the ways to use Seafoam.
            It does work . I did this to our old beater of car, 84 Pontiac, and it did run much better.
            78E ... Gone but not forgotten
            2006 Kawasaki Concours....just getting to know it
            • egsols
              • Jan 2006
              • 1090
              • Barrie, Ontario, Canada
              Hey Axel,
              See this thread,
              I asked the makers of seafoam your question yesterday!
              Ernie
              • Axel
                • May 2007
                • 869
                • Renfrew,Ontario
                Seafoam to the rescue
                Thanks guys .
                I was leary about pouring it onto a hot piston so I let it cool off for an hour or so . I noticed in the video they dont mention changing the oil in the car that they pour the seafoam into the oil ...
                I may not turn the engine over unecessarily as there may be a lack of lubrication . On start up I will unhook the plug wires and crank to get oil pressure then re-connect the wires .
                I plan to change the oil but I may run it a bit first to clean the crankcase
                XJ1100K
                Avon rubber
                MikesXS black coils
                YICS Eliminator
                • Crazcnuk
                  • 2980
                  If you read the directions on the Seafoam can, it says you can put some in the oil and leave it there.
                  Just depends on how much your going to put in.
                  '05 ST1300
                  • Montreux_Blue
                    XS-XJ Guru (Deceased)
                    • 1143
                    I'm sure they are generalizing for car/ truck usage. I would change the oil, never know what it could do to the clutch. I have put some in the Firebird to stabilize the fuel while it sits awaiting restoration, starting it once a month of course.
                    Famous Myspace quote:
                    • Axel
                      • May 2007
                      • 869
                      • Renfrew,Ontario
                      Deep Creep
                      I saw in the video that they said only to run a diesel engine one hour and change the oil .
                      This afternoon I purchased a can of Deep Creep and srayed in all the intake /vacuum ports to soak . I hope I got a lot of the plenum. I read that they get pretty carboned up and cause a vibration (which I have in abundance) . Pretty cool stuff - I ended up pretty well painting the whole engine compartment with it .
                      I also sprayed some in the vac ports on the running bike . Smoke was produced everywhere so I may have a few exhaust leaks !
                      XJ1100K
                      Avon rubber
                      MikesXS black coils
                      YICS Eliminator
                      • Axel
                        • May 2007
                        • 869
                        • Renfrew,Ontario
                        Thin oil
                        Today I checked my oil level to see if it had gone up. It had by about a quarter of a quart . The oil was so thin that I couldnt see it right away . I had to hold it to the light and check the back of the dipstick to see it . It is very thin . I hope it will be ok to drive it a couple of miles to the Walmart to get it changed . My plan was that this drive would clean my crankcase . I guess I need not add any more Seafoam to the oil .
                        XJ1100K
                        Avon rubber
                        MikesXS black coils
                        YICS Eliminator
                        • Crazcnuk
                          • 2980
                          "I'm sure they are generalizing for car/ truck usage. I would change the oil, never know what it could do to the clutch."
                          I hope it cleans the clutch. I can't see that it would hurt it.
                          '05 ST1300
                          • Montreux_Blue
                            • 1143
                            I was thinking slipping/ burning if left in and driving around with "thin oil", right?
                            • Crazcnuk
                              • 2980
                              I would assume that the amount they say to put is not going to thin your oil right out.
                              But that's just me.
                              '05 ST1300
