Man it's great getting to be #1 every now and then!!
OK, that actually was calculated on US gallons, namely 3.88 liters = 1US gallon.
The 41 mpg was after 120 miles on windy coastal highway, averaging 50m/hr.
My bike I imported from Chicago, it has the US speedometer, so my miles did not have to go through a conversion calculation.
However, you are right, that after my float adjustment I did run a bit lean, and had to back off my idle adjustment screw. ( Is that the right name for the adjustable brass screw facing the front on the carb? Not sure on the terminology here)
So now it starts easier again on cold mornings , and the mpg's are 38-39mpg.
Any comments on this?
Would it be better to get back to the float and adjust the tap to close a bit later, to make the bowl fuller?
80 1100SG with 79 engine
79 1100F being restored
78 xs650 runabout (mpg, eh?)
Irreverence is the champion of liberty and its only sure defense
Well i have been rideing my 1980 XS11SG right @ 8 months and i have put a header retuned the carbs new main and pilot jets and with me and my wife on a ride from Fort Worth to dublin Texas we got about 32 MPG at about 70 MPH avrig is that good or bad
