The overall purpose of using a shot of starter fluid is to isolate the problem to fuel or spark. If you have a plug that is not firing, you'll get no response when you give that cylinder a shot of fluid into its carb. If on the other hand its a carb problem, and the plug is sparking but the cylinder is not firing because of a carb problem, it will most times fire breifly when the fluid is introduced to the carb.
Proper troublshooting procedures should be to isolate the problem to the circuit that is at fault first, then isolate the problen within that circuit.
Steve
Steve
