#1 no spark coil to sparkplug
  • LoserShoes
    • Apr 2005
    • 524
    • Bangor Maine
    #46
    The overall purpose of using a shot of starter fluid is to isolate the problem to fuel or spark. If you have a plug that is not firing, you'll get no response when you give that cylinder a shot of fluid into its carb. If on the other hand its a carb problem, and the plug is sparking but the cylinder is not firing because of a carb problem, it will most times fire breifly when the fluid is introduced to the carb.
    Proper troublshooting procedures should be to isolate the problem to the circuit that is at fault first, then isolate the problen within that circuit.
    Steve
    73 Yamaha DT3 - DirtyHairy
    CZ 400 MX'er
    68 Ducati Scrambler
    RC Planes and Helis
    • mason79
      • Mar 2006
      • 1351
      • los angeles, ca
      #47
      you see guys the problem was the pilot circuit and thanks for the help, but like i said before, with the engine running on 3 cylinders,
      i would one by one pull the plug caps, away and each and every time the engine would stumble, indicating that i was the reason the spark was not in that envirorment, when i did it for #1, it did not stumble
      this led me to believe no spark exsisted to begin with but now i know that the spark was not there because the air fuel ratio at a given rpm range mainly, off idle did not allow the spark to jump or was weakened.
      this cause the filling up of the cylinder and overriching from the enrichment and never allowing the delicate balance of components and events to take place in that cylinder for ignition.
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
      • airborneXS
        • Feb 2012
        • 338
        • Houston, TX.
        #48
        i know, old post, but im having the same issue.... ive been riding it for awhile, and it seems to run great, now that ive gone through most everything, but every now and then there is a hesitation or stumble or whatever. i checked my pipes this morning and #1 was cold. so now i know whats going on, but i think it may only be at idle....
        79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
        09 YZF-R1 " Toothless"
        04 Buell XB12R "Butterfly"
        "I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
        Wolf
        Moto Militia MC
          Intermittant miss............tug on theose pic-up coils wires every inch looking for stretching in the insulation. That'll be where a break is. You'll be chasin' your tail othewise.....
