After the forks, I thought I was set. I took her (my 78XS11E) out for a ride with a friend on his new Vulcan. Anyway, She seemed to be running ok at first, but after just a few miles (maybe 15 or so) she started running really rough, especially at low speeds. She wouldn't accelerate hardly at all, and the engine doesn't sound right, kind of a deep muffled sound. After another a few more miles (maybe another 15) she got to the point that she would barely move at all, wide open on the throttle and she was doing maybe 20 miles per hour and running really rough, then all at once for a few seconds she would run ok again, but only for a few seconds. I pulled over and smelled gas... this got my attention. After she cooled down she at least started again but only if I held the started button in for about 30 seconds, she used to start almost instantly. I didn't have a plug wrench so I limped to an Auto Zone parts house, bought a spark plug socket and wrench set, pulled the plugs, #2 looked clean, the other 3 were completely cover with black soot, really covered really bad. I replaced all 4, she still didn't start or run any better, but I got her home. Any help on where to start, I would sure appreciate it.
She (at least the engine) was running GREAT, this literally just happened.
But now to more serious matters! With your floats sticking, there's a chance you could have gotten some gas into your oil, by it leaking into the intake, past the valves, rings, and down into the oil!
You'll want to check your oil for presence of gas mixed with it! If so, you'll need to change it, you don't want to spin a bearing, or score/gall your cams or crank!!
