while my gas tank gently seeps
Most radiator shops will clean and seal gas tanks. I did one years ago. Of course back then the price was reasonable. The only thing to be sure of is to ask them about the process and what products they use.Last edited by cajun31; 11-20-2026, 06:14 PM.2 - 80 LGs bought one new
JimComment
☮Comment
Gasket is arriving today. I'll have to see the new one compared to the old one set in there. And I'll check radiator shops or try to seal the original tank. I don't want to let it sit and rust. I could use it or one of y'all could...
The petcock had a lot of rust particles from the tank. Does the filter on it work ON RES and PRI? That gunk can get on the rubber gasket and cause a seepy leak. I gotta clean it up.80 GComment
Yes it does.The petcock had a lot of rust particles from the tank. Does the filter on it work ON RES and PRI?2H7 (79) owned since '89
☮Comment
Might be okay. Sanded a bit. New gasket. Filled tank rode 30 mi. Needs to sit overnight to be sure after temp and pressure changes.
A long long time ago in a land far away in NY in the rain. I was riding an 850 and hit reserve so I thought -it was empty. I pushed it til the last hill, front brake, push, gasp, into gas station. Filled it up and found out when the tank was painted they left out reserve.80 GComment
☮Comment
Looks like the rings from Harbor Freight. I have found that the orings that come in most of the carb rebuild kits are too small and don't make a good seal against the tank. I use these and never have a problem.2 - 80 LGs bought one new
JimComment
That 850 special made it to Miami in 1990 then leaked gas out out of the same spot. I remember the fiber washers might have fixed it.80 GComment
You know Jim, this Harbor Freight kit really doesn't have the correct sizes for both the Standard and Special type petcocks. They have to be stretched slightly, which to me is only a temporary solution, especially when dealing with gas. Over time they may be more prone to fail. You are right, the larger cross section does seal better to the tank.Looks like the rings from Harbor Freight. I have found that the orings that come in most of the carb rebuild kits are too small and don't make a good seal against the tank. I use these and never have a problem.Last edited by bikerphil; 11-22-2026, 07:12 PM.2H7 (79) owned since '89
☮Comment
Looks like radiator shops don't exist anymore. A starter rebuild shop guy told me there may be one left in a more industrial city.80 GComment
☮Comment
Almost all the Auto parts chain stores sell fuel safe o-rings individually, they have them behind the counter, just ask1980 XS1100G
Intelligent people discuss ideas, average people discuss events, petty people discuss other people.Comment
