Looking Great ........... nice fix
At least now I don't have to worry about seeing a big fire ball in my rear view mirror.
Heck, with that new Go Fast 78' Macho Maroon tank now we can follow you.
J
while my gas tank gently seeps
Yea. I rinsed it out with gas to get particles of rust out. One petcock was leaking, so I swapped gaskets and sanded the surface. now it's dry.
It was a tighter fit to install. Looks like original 78 macho maroon, pretty clean from rust and damage.Leave a comment:
Nice, I told you it would be faster
How does it look overall, pretty solid?Leave a comment:
Yep, my friend Cobia (RIP) had the exact same tank and he tried to patch it like you did and it didn't work out. He used the tank sealer in the back of the tank only and it was good after that. I can't remember the sealer he used, I want to say POR 15 but I can't be sure.Last edited by bikerphil; 11-14-2026, 02:42 PM.Leave a comment:
I should still repair this tank. It is leaking through or near the putty. I slowed it down. The tank sealer, jb weld are good products that work. most failures are probably user error. The tank sealer/liner has to be done just right. I may try it or get help to do it.
I did a thorough job wth th jb tankweld, let it set overnight. Maybe I missed a pinhole or didn't adhere it ti the metal enough in a spot that needed it?Leave a comment:
The seam should be an relatively easy repair with a high watt soldering gun, done that before with good results.Leave a comment:
seeping out maybe from another spot. the shop said he could repair the edge seam .. I don't know
😞 1Leave a comment:
It's OK like that, it's a vent, it should point upward and hooks to nothing.Leave a comment:
small hose going to the back below the crank breather maybe out of middle drive goes upto nothing ok or not ok?
Leave a comment:
It's 6.3 gallon, the inside looks pretty clean, the picture of the inside shows shiny metal, maybe a tiny amount of flash rusting which wouldn't be a deal breaker. I would run it with a fuel filter anyway which would catch anything. It's pretty normal for some flash rusting to occur with it sitting dry.Last edited by bikerphil; 11-12-2026, 06:13 AM.Leave a comment:
Leave a comment:
