Brake caliper part
    • 2096
    Brake caliper part
    On my 1980 SG the brake caliper has a metal clip that is in the center. Is that necessary and what does it do? The reason I ask is the pads sit above that. Is that normal? Shouldn't the pads sit kind of flat? I examined the caliper today and no crud at all. The other caliper has a bent bolt that is kind of hard to remove.
    • 3361
    The clip sits in the center of the caliper, with the pads resting in it or on it? Like it's a spring-loaded clip that would put tension on the end of the pads?
    2001 ZRX 1200
    1982 Seca 750
    1983 Nighthawk 550
      • 2096
      Ok the one caliper is definitely not dragging but have to work on the other caliper as I think I have a bent bolt if that's possible.
        • 3361
        Interesting...
        2001 ZRX 1200
        1982 Seca 750
        1983 Nighthawk 550
          • 8933
          It's an easy to find bolt replacement at a hardware store, get the hardened 10.9 version, it won't bend as easily. This is somewhat of a common problem on the Special's 'Weird Harold' calipers.
          The spring clip when properly installed should keep the pads from rattling.
          Bolt size should be M8X1.25X90
            • 3361
            Agree it puts pads under tension and keeps them from rattling around. The way it was described I wanted to confirm. But there's only one spring clip.
            2001 ZRX 1200
            1982 Seca 750
            1983 Nighthawk 550
              • 2069
              I can't run that caliper pad screw with my 15 inch rear wheel because there is no access (not even through the cut-outs of the Centerline rim). Over 10,000 miles with no issues. But I would use the screw if I could.
                • 2096
                I think I have the bolt in my Yamaha parts box along with other new items I bought years ago. Bike Bandit was my go to parts place. Now E -bay is good to find parts. I'm going to put some Kroil on the bolt and let it sit. Also I was using a 3/8 ratchet with a flex head and will get my other ratchet at my Moms house. Its raining all day in N.J. so not much will be done today on the bike.
                  • 3361
                  Are you able to see the bolt is physically bent? Could it have been cross-threaded?
                  2001 ZRX 1200
                  1982 Seca 750
                  1983 Nighthawk 550
