Brake caliper part
    • 2095
    Brake caliper part
    On my 1980 SG the brake caliper has a metal clip that is in the center. Is that necessary and what does it do? The reason I ask is the pads sit above that. Is that normal? Shouldn't the pads sit kind of flat? I examined the caliper today and no crud at all. The other caliper has a bent bolt that is kind of hard to remove.
    • 3359
    The clip sits in the center of the caliper, with the pads resting in it or on it? Like it's a spring-loaded clip that would put tension on the end of the pads?
    2001 ZRX 1200
    1982 Seca 750
    1983 Nighthawk 550
      • 2095
      Ok the one caliper is definitely not dragging but have to work on the other caliper as I think I have a bent bolt if that's possible.
        • 3359
        Interesting...
        2001 ZRX 1200
        1982 Seca 750
        1983 Nighthawk 550
          • 8933
          It's an easy to find bolt replacement at a hardware store, get the hardened 10.9 version, it won't bend as easily. This is somewhat of a common problem on the Special's 'Weird Harold' calipers.
          The spring clip when properly installed should keep the pads from rattling.
