Was good until last week
    • 2100
    I will go to my storage unit today and connect a carb "T" to the carb fuel lines and run an auxillary tank so I can be sure the carbs are clean before I fill the fuel tank. I bought 4 ft' of Tygon 1/4" fuel line and replaced a brittle fuel line.
      • 3361
      Looking forward to hearing that it started up crisp and clean!
      2001 ZRX 1200
      1982 Seca 750
      1983 Nighthawk 550
        • 2100
        Ok so I did the bread-tie sync method after I cleaned the carbs as I have had very good results with that method. I then do a sync using my Morgan carbtune. I attached the auxillary tank and got fresh gas to test. The oil light stayed on but went off. I did not lower the idle and the bike started no issues but then the idle started to raise. I shut off the bike and played with the idle screw and then it would not start unless I gave it some throttle. I finally got the idle just right and the bike is again purring. I disconnected the auxillary tank and added fresh fuel to the fuel tank and bike started no issues. Now I have a dragging left brake caliper that needs some cleaning.
          • 3361
          Good to hear it's running well! Keep us posted on the caliper.
          2001 ZRX 1200
          1982 Seca 750
          1983 Nighthawk 550
            • 2100
            Yes supposed to rain tomorrow and my back is screaming at me. so most likely will work on the caliper during the week. I will start it tomorrow though as I love the sound of the Kerker exhaust.
              • 3361
              If you're going to pull the piston out of the caliper, leave the brake line hooked up to use the brake lever to extend the piston easily once the caliper is removed. You probably knew that but just a reminder.
              2001 ZRX 1200
              1982 Seca 750
              1983 Nighthawk 550
                • 7835
                My one XS1100 with a Kerker was my best sounding bike, by far. I loved the sound and quality of that system. Anyone who was on the California highway 1 trip years ago probably remembers it as well. When I opened it up, it screamed.
                  • 2100
                  Its a sweet sound. My Mom said she could hear my bike halfway down the street if she was in the house.
                    • 2100
                    I went to go start the bike today and did some micro tuning of the idle knob. I always forget which way to turn the knob. I have it at idle warmed up at around 1,200 rpms according to the tachometer. No leaks coming out of the carb bodies. I have to get my Morgan carb tune and do a sync.
                      • 2100
                      Tomorrow I will also check the spark plugs as part of my maintenance. I still have brand new in the box NGK BP 6 ES plugs hat I bought at the local Napa years ago.
                        • 2100
                        I replaced #1 spark plug as it was fouled.. I cleaned it with contact cleaner but had replaced it with a newer plug. The bike runs and idles and doesnt shut off. The exhaust pipes all are hot. Got to tell myself not to touch hot exhaust pipes. I recorded a video but am having issues sending it to my e-mail
