Where is my oil going?
  • Ccitis
    • Jun 2023
    • 213
    No smoke... no leaks... no obvious place it is going. Running Lucas 20-50. Everytime I go for a ride lets say around 300kms, there is no oil in the sight glass when I get home. Bike on the center stand. Where is the oil going? I don't get it.
    Valve seals will leak oil past them and can burn with none or very little visible smoke. If you are running synthetic, that smokes even less. I have this problem with my 79sf, only my friends riding behind me can smell it.
    • Tropic-al
      • Nov 2009
      • 176
      • Tampa, Florida
      So you have burned all that oil in a couple hundred mile ride ?? Does it take longer to fill back up at least some ??
      If not, how much are you adding to get to the level mark ??
      79 XS1100F.
      TC's fuse box.
      SOFA filter.
      Venture cam chain adjuster.
      Tkat fork brace.
      Progressive fork springs.
      • Ccitis
        • Jun 2023
        • 213
        say 250ml to fill. Conventional oil only. It seems very odd to me. I would think valve seals would not burn that much oil....
          The noticeable symptom of valve seals leaking:
          After the bike has sat unused for a period of time (a few weeks),... when you start it, it will make a lot of smoke. The smoke diminishes after the oil burns off the exhaust ports in a few minutes.
Name:	1 Valve.jpg
            If you're running steadily above say 4500 rpm, the consumption will be greater. Worn rings, same deal. Check your motor for blow by.
            My friends XJ11 had the same issue. We did new rings, ball hone the cylinders and new valve seals, oil consumption problem gone.
              Yes, the top end needs both rings and seals and it will last another 45 years. These are just normal wear items. However, don't use Chinese crap parts when replacing.
              • Ccitis
                • Jun 2023
                • 213
                I am going to do some tracking to see how much oil it is really going through. No symptoms of burn, the top of the valves were dry last time I was in there. Motor only has 23k miles on it, although I know rubber seals can go bad when sitting. I get some misting on the left side on the frame under the shifter cover which I just put a new gasket and shaft seal on (annoying).
                  Maybe have a buddy riding behind you check/smell for smoke.
                    You mentioned mist on the left side. Give the bike a good cleaning and then take it for a ride after it dries and immediately inspect for where that mist is coming from.
                    • Ccitis
                      • Jun 2023
                      • 213
                      Its coming from under the shifter mech cover. I re gasketed it and put a new seal on the shift shaft before the season. Didn't work!
                        It could also be leaking from above the shifter cover, particularly from the bearing cover to the left of the starter. There are two O rings under there.
