Cylinder Head Cleaning
    • 3973
    I want to do this right and not rush it. I have half the valves and valve seals out. A few questions on proper cleaning. I plan on submerging the head in a hot bath of Simple Green:
    1. Mating surface: The head mating surface has some gasket material baked into it. After soaking, can I use a brass brush to remove it, or a gasket scraper only?
    2. Cylinder bowls: Brass brush okay to remove carbon?
    3. Valve stems: I read to NOT use any brushes, etc. on valve stems. No brass brush to remove carbon?
    4. Valve guides: Can I use a brass wire pipe cleaner?
    • 8064
    Paint stripper has proven effective at helping me remove old gasket material.
      • 3973
      It actually came right off with a pass of the gasket scraper. I'm soaking the head as we speak in a heated bath of Simple Green and water. I'll drop the valves in my ultra sonic cleaner to see if it'll beak-up the carbon deposits.
        • 2144
        I used a brass wheel on a bench grinder to clean my valves. It worked well and did no damage to the valves. They came out like new. It did take a little patience.
        After carefully removing the carbon and gasket residue from the head, jugs and pistons, I used a Dremel brass wheel for the final touch. It worked well and did no damage.
          • 7821
          Make SURE you rinse the head VERY WELL!! Simple Green is very bad for aluminum. It's use in not allowed on aircraft.
            • 3311
            I would second a brass brush or even a brass brush attachment on a Dremel tool, they work great on aluminum brake caliper piston bores and grooves, cleaning the inside of brake and clutch master cylinders on different bikes.
            2001 ZRX 1200
            1982 Seca 750
            1983 Nighthawk 550
              • 3311
              I would second a brass brush or a brass brush attachment on a Dremel tool, they work great on aluminum brake caliper piston bores and grooves, cleaning the inside of brake and clutch master cylinders on different bikes.
              When I rebuilt the head on the ZRX, back of exhaust valves and stems were carboned up. The Dremel tool with a brass brush made short work of them.
              2001 ZRX 1200
              1982 Seca 750
              1983 Nighthawk 550
                • 3311
                With respect to Simple Green and aluminum, worst I've seen is it discolors aluminum. I did a number of carburetor sets years ago with simple green and a homemade vibrator / ultrasonic cleaner. The aluminum darkened (more gray and dull) but everything worked fine. I've never had an issue otherwise. What is the reason for not being allowed in aviation?
                2001 ZRX 1200
                1982 Seca 750
                1983 Nighthawk 550
                  • 1993
                  Howard,
                  This is Google AI's take on it: Standard Simple Green All-Purpose Cleaner is bad for bare or unprotected aluminum because its alkaline, water-based (aqueous) formula accelerates oxidation and corrosion. Leaving it on too long can cause pitting, discoloration, and a white powdery residue (aluminum oxide), or even trigger hydrogen embrittlement in high-strength aerospace alloys.
