Brake Pad Knock Back
Sounds weird for sure. Have you verified that the spooge hole is completely clear? Brakes not releasing? Clogged Spooge hole? - XS11.club Forums I know the maintenance tip reads not releasing but what you are describing about the handle going soft all the way to the grip indicates the fluid is not releasing properly. Sort of like a vacuum problem which leads back to the spooge hole. Just something easily checked. One other thing and it has been mentioned. Have you closely inspected the master cylinder bore for pitting etc, Has it been cleaned or honed to the point of being too far out of spec and the rubber on the plunger is not sealing properly. Have you noticed any brake fluid seepage at all? The brake system on these bikes was never the best to begin with but if properly cleaned they do the job. Sounds like you have been through those brakes a number of times already but if I were sitting in front of that bike I would be completely disassembling everything and making sure everything is cleaned, flushed and spotless. Throwing parts at the problem before being completely sure of what the problem is to begin with can get costly.2 - 80 LGs bought one new
JimComment
