Master Cylinder Rebuild - Plunger rubber installation
  • xs11
    • 130
    by Ken Talbot, 2/26/02
    I'm really stumped. Any ideas on how the rubber seal is placed onto the plunger inside the master? It is a small rubber cap and the plunger has a large diameter disk at either end and the seal goes in the middle. The old one is in the center of the plunger and the rebuild kit has the parts separated. At $60 bucks
    Canadian I'd hate to mess it up.
    Dave Jardine
    The rubber seal is quite flexible, Dave, and will take quite a bit of
    twisting without tearing apart.
    Start with the plunger and seal laid out like this, to be sure of which way the seal is going to face
    Roll the seal inside out and slide it up the shaft of the plunger so is comes up against the collar
    Slide a flat screwdriver blade under the seal and up onto the collar
    Lever the screwdriver over to start bringing the seal into position. Get it far enough over so it won't slip back. Notice how the seal is turning back to right side out as this happens
    Use your fingers and thumb to roll the seal the rest of the way over the collar
    Check that the seal is sitting in its groove where it belongs.
    Voila - you're done!
