brights
  • speedlimit85
    • Jan 2017
    • 446
    • Gainesville, Fl.
    brights
    So the blue dash light is on a bit with the low beam and a lot with the brights. The high and low are kind a mixed together. Both work .. is this common? What wires do I look at to make it work correctly?
    Could this be related to my signals blinking slower sometimes? I'm not strong with complicated electric. I can grasp direct inspection and repair and ground cleaning if I know the right spot.
    80 G
    • 8061
    The reserve lighting unit turns the high beam on at reduced voltage when the low beam fails. Did your low beam filament fail? Check the headlight first.
    • speedlimit85
      • Jan 2017
      • 446
      • Gainesville, Fl.
      Changed headlight bulb- works great. That means the dash bulb reserve light indicator must be out.
      80 G
        • 1987
        could be this yamaha 3h5-81950-00-00 could be acting up on you. They can corrode on the inside and the symptoms you describe can be the result. There was a thread in the past where one of our member actuallypried one open and cleaned it and made repairs to it. As you can see it can be had on Ebay, only problem being you don't know if you are getting anything any better than what you already have. That box is located under the tank along the frame towards the headlight bucket.
        • speedlimit85
          • Jan 2017
          • 446
          • Gainesville, Fl.
          The little indicator bulb had disintegrated. So it all worked as it should.
          80 G
          • speedlimit85
            • Jan 2017
            • 446
            • Gainesville, Fl.
            3h5-000-415
            80 G
              • 2009
              To eliminate the reserve lighting unit (If you chose to do so).
              Click image for larger version  Name:	XS11 Lighting Device Mod.jpg Views:	0 Size:	108.5 KB ID:	889865 Click image for larger version  Name:	XS11 Lighting Device Mod A.jpg Views:	0 Size:	192.6 KB ID:	889866To eliminate the headlight relay:
              Click image for larger version  Name:	Headlight relay.jpg Views:	0 Size:	178.4 KB ID:	889868 Click image for larger version  Name:	Headlight relay Eliminate.jpg Views:	0 Size:	156.4 KB ID:	889867
                • 2009
                This is how the modification works.
                Low beam: Click image for larger version
Name:	Reserve Lighting Eliminate Low.jpg
                High Beam:
Name:	Reserve Lighting Eliminate High.jpg
                  • 2009
                  I found this post. This guy used crimp connecters. I soldered mine with heat shrink tubing. Either way it works.
Name:	Reserve Lighting plug mod.jpg
                    • 8061
                    The only time I ever needed the reserve lighting unit I was glad to have it. 30 minutes from home, leaving a bike night, and poof, the low beam failed. The trip home was uneventful.
                      • 2009
                      This happened to me once on another bike. I used my left thumb and switched to the other bulb.
                        • 8061
                        I assume you know that’s not the same thing.
                          • 2009
                          Yes, and I should have said filament.
                            • 8061
                            I meant to point out that the reserve lighting unit operates the high beam in dim mode if the low beam fails. It allows you to limp home at night without blinding oncoming drivers.
                            I’ve been operating XS motorcycles since 1983 and the feature saved my bacon exactly one time. It failed upon “bike night” departure.
                              • 2138
                              I have appreciated that feature twice since 1980.
