JASO oil vs energy conserving
    • 3352
    Tried posting this in the members Lounge but it has a pink background and says unapproved. Not sure what's going on? Going to give it a try here.
    I spend a good bit of time over on "Bob is the oil guy" forum. Discussions about JASO MA/MA2 oil rating going on at any given time.
    I'm looking for info/experience back in 1997/1998 when energy conserving became a label on bottles in 1997 then JASO was established in 1998.
    My question is this: Even though oils above 10w30 grade are not rated energy conserving simply because the higher viscosity discounts them from an engine efficiency standpoint, has anyone experienced issues with clutch slippage during the 1997/1998 time frame or after, running "Automotive" 10w40, 15w40, 20w50 Etc in any bike not just a Yamaha XS1100?
    My contention is if it doesn't have "energy conserving" on the bottle, there's no magic pixie dust that is a friction modifier other than traditional additives such as boron, moly and zinc.
    Over on BITOG, guys are adamant about friction modifiers that somehow make a difference, yet no one can identify them and the potential to be in oils that are not labeled as energy conserving. However I've never had an issue myself and I'm trying to get some real world experience from others besides myself that I can share back on that forum.
    2001 ZRX 1200
    1982 Seca 750
    1983 Nighthawk 550
    • 837
    Can't say this applies directly to the XS but there's plenty of stories on the Suzuki GS forum on clutches slipping while using friction modifiers. Considering those bikes are from the same era I always shied away from using it.
      • 2007
      My 2 cents. I used Supertech 20w50 from Walmart in all my bikes for years and it caused no slippage. I used to use Yama lube 20w40 and when that became unavailable i went to the Supertech. The only reason I don't still use it is because I have read that continued use of oil intended for use in an automobile, even if it does not have any friction modifiers in it, does not have the shear strength that oils specifically manufactured for motorcycles has. Even though that oil is probably better for the clutch, the real problem with most motorcycles is that the same oil is shared by everything whereas in a car only the engine. Most motorcycle oils have additives in them to prevent them from breaking down under those extreme conditions. Now, with that said, on our old bikes or for that matter any of those bikes from that era generally have a stated oil change frequency of 3000 miles so it probably isn't that big of an issue. Other things I have read is that the use of oil intended for cars over prolonged use in a motorcycle can cause more sludge buildup. Can't say I don't somewhat agree with them on the other forum about making sure you are using oil marked with those Japanese oil standards. Yama lube 20w50 no synthetic is still available so would be a good choice for oil.
        • 8930
        Castrol GTX or Supertech 20W/50 non synthetic, change every 3K religiously, filter every 6K, just like the book says. Motors are gonna last a long time. Like 150-200K+. No friction modifier additives to preserve the clutch. Used Castrol 89-05, then switched to Supertech and still using.
          • 2160
          I've used Castrol 20-50W (automotive) oil in all my motorcycles since 1980. No clutch issues and no sludge issues.
          I usually change the oil after about 2,000 miles.
            • 2057
            I have used either Mobile 1 or Shell 15W/40 car oil in literally hundreds of motorcycles. I have also literally circled the planet with my personal bikes several times (mileage wise) with this oil and never had an issue. The "Oil online argument" is the oldest cult in the world and will continue to churn out B.S. long after we are dead. 😉
            Click image for larger version  Name:	Alaska021.jpg Views:	0 Size:	170.8 KB ID:	889563
              • 3352
              Thanks for sharing those responses fellas. I have never had an issue. And yes, there's (potentially) a lot of BS when guys talk oils on the Internet or anywhere else.
              2001 ZRX 1200
              1982 Seca 750
              1983 Nighthawk 550
                • 297
                also a Supertech 20/50 w...user,,,being low priced and always available,,,been using it for a long time with zero issues, change every 4000 and filter, just wish the filter was easier to change, I never had the spin on adapter, anybody chime in on that mod?? Mike in S.Diego and Pa.
                  • 837
                  Word has it the VMax spin on filter adapter kit works on the XS. The thing is with the XS you have a cast aluminum housing directly behind the front wheel to block whatever rocks or debris you might come across as opposed to a relatively thin piece of stamped steel with the spin on.
                    • 2057
                    https://www.ebay.com/itm/26104538583...Bk9SR5S6gZC_Zw
                      • 8077
                      I’ve been living with the OEM design since 2003. I decided a long time ago that for me, it wasn’t broken. I’ve been using Wix 24933 all this time. It really isn’t significantly more messy than the upside down filters on my cars.
                        • 837
                        Here's a first hand account on having your oil filter getting penetrated by a rock when you're out on the road. Scotty has been wandering since 1995!
                          • 8077
                          I put a project XS11 on the lift. The oil in it is at least 10 years old, could be twice that. I’m going to drain it and put in fresh. What’s the cheapest acceptable oil? I won’t even be running it. It’s only for preservation.
                          I did same with brake fluid. It will be better when I get after it for having done that.
                            • 2057
                            Walmart Supertech. It's good oil.
                              • 2057
                              https://youtu.be/yftL_mFjnkI?si=UZueLZiRWhCNwkuM
                              LAB3, I am also a big fan of Scotty. Go figure. He is no Credit Card.
Name:	Scotty. The man..jpg
