Hey, Team! Dragging up an old thread, and hoping to consolidate the info into this one here. My BS34 carbs work great. But, I'm contemplating going the ZRX1200 route, as I plan to keep the bike forever, so why not treat it to some modern carbs? I understand the following:
Anything to add?
- The carbs need to be re-jetted
- The carbs are not spaced perfectly, but close enough
- The carbs need a choke kit fabbed and installed
- The carbs need a vacuum port drilled (TAD's thread)
- What about the ACV system at the end of the carbs with the electrical connector? What do you do with that? Is there a block-off plate if you remove it?
- Would the RS36 carbs from the Oz site be any better or worse than the ZRX carbs, besides cost savings on the ZRX carbs?
- Is everyone staying with the modified single throttle cable, or did anyone go with a push/pull cable?
Anything to add?
