ZRX1200 Carbs vs RS36 Carbs
    • 4015
    Hey, Team! Dragging up an old thread, and hoping to consolidate the info into this one here. My BS34 carbs work great. But, I'm contemplating going the ZRX1200 route, as I plan to keep the bike forever, so why not treat it to some modern carbs? I understand the following:
    • The carbs need to be re-jetted
    • The carbs are not spaced perfectly, but close enough
    • The carbs need a choke kit fabbed and installed
    • The carbs need a vacuum port drilled (TAD's thread)
    My questions:
    1. What about the ACV system at the end of the carbs with the electrical connector? What do you do with that? Is there a block-off plate if you remove it?
    2. Would the RS36 carbs from the Oz site be any better or worse than the ZRX carbs, besides cost savings on the ZRX carbs?
    3. Is everyone staying with the modified single throttle cable, or did anyone go with a push/pull cable?
    TADracer oldyam80sg xschop
    Anything to add?
  • red bandit
    • 970
    • central michigan
    When I was running ZRX carbs I didn't notice any difference in performance or gas milage (I didn't do the vaccum port so you may gain some milage) so you really don't gain anything other than they are newer carbs and you need to do some work. But your old ones work fine so why change things unles you are just looking for something to do and that's fine. BTDT. I just left the wires hang there. The carbs fit fine. I used a manuel choke kit from the auto parts. I used the original single throttle cable and modded the carbs linkage. I did a little welding.
    79 SF parts bike.
      • 4015
      Sounds like I'll stay with my carbs, and ensure they get some love in the Spring with a good ultrasonic cleaning and new throttle shaft seals.
        • 3372
        -You can remove the KTRIC (TPS is all it is) from the carbs, which simply sends an electronic signal to the ECU to adjust ignition timing based on butterfly shaft opening. The end of the butterfly shaft will be exposed where it slots into the KTRIC. You can cut a piece of aluminum to make a cover with snips and use the screws to hold the cover in place.
        -For the enrichener (choke) take a key ring and hook it on the left end of the choke shaft that sticks out on the side. Then you can pull the choke out and hold it long enough for the bike to warm up. Or remove the choke lever return spring and you have to manually make sure the key ring is pushed all the way back in to turn the enrichener off. But then you wouldn't have to hold it against spring tension while it warms up.
        -Unless you're running a different ignition, you have to drill a vacuum port if you want the vacuum advance, no two ways about it.
        -As red bandit said, no increase in mileage or performance was the fact there was no vacuum port and the vacuum advance was neutered. So if that's comparing to stock carbs, getting the vacuum advance back online is going to improve both of those.
        2001 ZRX 1200
        1982 Seca 750
        1983 Nighthawk 550
