Upgrading coils
    • 2057
    You could always just Torch your motor if your getting bored.
Name:	Torch your motor.jpg
      • 2057
      NGK Site and where to buy genuine NGK plugs:
      NGK nickel copper core spark plugs deliver original equipment quality and performance to your engine.
        • 8077
        Originally posted by Larrym
        PLEASE tell me they are like the LB05F (short 90 degree for the outer cylinders) and the XB05F
        Larrym I tried to send you a PM. You're blocked.
          Umm..... (•_• )
          Yup. Not a site error or an oversight on my end. ( •_•)
          Just part of my own "policies-and-practices" changes between the ole DOT Com site and this new fangled Dot CLUB version. ヽ(゜~゜o)ノ
            • 8930
            Just a note about the green Dynatek coils...
            You will need to use either resistor caps or resistor plugs. If not, using a multimeter on the running bike will be impossible due to the heavy RF interference put out by these particular coils. They may interfere with other electronic devices as well.
              • 7830
              That is true of ANY coil! Resistor wires, caps, and plugs came about because of interference on the AM radio bands for the car radios.
                • 8930
                Yep, but these seem to be especially dirty. The Accels not quite as bad.
