Upgrading coils
    You could always just Torch your motor if your getting bored.
Name:	Torch your motor.jpg
      NGK Site and where to buy genuine NGK plugs:
      NGK nickel copper core spark plugs deliver original equipment quality and performance to your engine.
        Originally posted by Larrym
        PLEASE tell me they are like the LB05F (short 90 degree for the outer cylinders) and the XB05F
        Larrym I tried to send you a PM. You're blocked.
          Umm..... (•_• )
          Yup. Not a site error or an oversight on my end. ( •_•)
          Just part of my own "policies-and-practices" changes between the ole DOT Com site and this new fangled Dot CLUB version. ヽ(゜~゜o)ノ
            Just a note about the green Dynatek coils...
            You will need to use either resistor caps or resistor plugs. If not, using a multimeter on the running bike will be impossible due to the heavy RF interference put out by these particular coils. They may interfere with other electronic devices as well.
              That is true of ANY coil! Resistor wires, caps, and plugs came about because of interference on the AM radio bands for the car radios.
                Yep, but these seem to be especially dirty. The Accels not quite as bad.
