Gas Leaking When Using The Choke
    • 2138
    I usd the K&L kit on my XS750 vacuum actuated petcocks and it was NG.
    I switched to manual aftermrket petcocks like I did on two of my XS1100's.
      • 8061
      The fix I posted works. It doesn’t take much.
      • Spartanman
        • Mar 2017
        • 19
        • Lake Odessa, MI.
        OK, I got the rebuild kit, took the vacuum block apart, and I am confused. The rebuild kit comes with the two thin membrane pieces that go on each side of the spacer. . It would seem the pins have to come out of the old diaphragm and the new one to do this. But I can't see how to get these apart and installed on each side of the spacer. Apologize if this is an idiot question, as I am mechanically challenged by most things. But any advice would be appreciated.
        81 xs1100LH
        75 Norton Commando
          • 7818
          You fold over the one membrane and tuck it into the hole of the block. At least, that is what I did.
          • Spartanman
            • Mar 2017
            • 19
            • Lake Odessa, MI.
            OK - disregard that last post as it was an idiot question. I gently bent the membrane through the hole and got the spacer out and aligned again.
            81 xs1100LH
            75 Norton Commando
            • pete_s
              • 112
              • NoBranford CT
              My 2 cents is the K&L kits is mostly fine but won't seal with the as issued o ring. I replaced the o ring I think to a smaller size, good for another 20 years! I love the system.
              1967 Bultaco Metralla 250
              RD125
              1973 CT3 175
              78 XS1100E
              80 XS850SG
                • 8893
                I just installed a Standard rebuilt vacuum fuel tap with the K&L kit today. I had to smash that metal part of the diaphragm in pretty good so the pin and O-ring would reach the newly polished seat. The first time I bashed it, it wasn't enough but the second time it seemed to be the right distance and then it sealed perfectly. I also stretched the return spring some. I used the O-ring that came with the new diaphragm, I didn't change the size. Thanks for that link/tip Marty.
