new clutch won't disengage
  • kevxs2
    • Jun 2025
    • 3
    Hi all, just installed a new clutch for the first time, I've been adjusting the cable but cant make the clutch disengage. I put the bike in gear and pull the clutch lever in but the rear wheel stays locked to the transmission. any ideas where I went wrong?
    • 7830
    Pull the cover so you can see the end of the clutch cable. There is a lever the cable is connected to. At the pivot point of the lever is a 10mm lock nut and a phillips screw. You will need to adjust this per the book. If I remember correctly, you turn the screw in until it touches and back out 1/4 turn. You will feel the resistance when it does touch.
    • kevxs2
      • Jun 2025
      • 3
      Thanks Ray, I've adjusted that as per the book, also I had the new clutch plates and friction disc's soaking in oil for over 24 hours before installing.
        • 2057
        Your problem could be here. Not installed correctly and binding. Sometimes they can crack.
Name:	Clutch springs.jpg
          • 2160
          Maybe there is just surface tension form the oil you correctly soaked the plates in.
          Try rocking the bike forward and backward with the clutch lever pulled in.
          • kevxs2
            • Jun 2025
            • 3
            Thanks guys, I put it on the center stand and ran it in gear and hit the rear brake a few times. That made it 90% fixed. Took it for a ride and all seems perfect now!
