Well, looks like my XS is going to stick around in my garage for awhile... it doesn't want to leave! Started to mark its territory leaking from the fuel sender area on the bottom of the tank. I previously used some fuel tank JB weld to try and stop this, replaced the sealing washers for the unit... no bueno. Back to the table. Also, seems the front calipers are hanging up. Tried clearing the splooge hole. No dice. Will have to pull the caliper and see whats going on with the pistons. I just put a new caliper kit and pads on both the fronts.
Leaky tank and dragging brake
Easy test is to crack one of the bleeder screws open and if it unbinds, it's the master cylinder spooge hole that is plugged. No change then it is a caliper(s) problem.
There is also a slight chance of it being a plugged up brake line, especially if you still have the old type rubber lines.Last edited by bikerphil; 06-09-2025, 09:25 AM.2H7 (79) owned since '89
☮👍 1Comment
New lines. I am sure it was that hole. It was so clogged (and way tinier than expected) I think old brake fluid had hardened it over. We will see. Went through the caliper again anyways... and took the master cylinder apart for a good clean.Easy test is to crack one of the bleeder screws open and if it unbinds, it's the master cylinder spooge hole that is plugged. No change then it is a caliper(s) problem.
There is also a slight chance of it being a plugged up brake line, especially if you still have the old type rubber lines.Comment
Seems to have fixed it, although waiting on the mail for my tank gasket. Bike was for sale... I think I will keep it kicking around. Nobody wanted it for little money. It is low mileage in good shape. No harm having it for awhile. As you all know, they are as solid as an old bike comes. Hopefully 2nd gear holds. Always my concern in the back of my head. Then again, I enjoy the wrenching too. I noticed lately when the bike is hot I need to blip the throttle start it. Not when cold. Cold on choke and half choke it runs well. But needs a little help to start hot. What do you think that is about. I don't think I am lean on idle....Comment
My guess is going to be that you are lean on idle. You don't have the pilot jet screws tuned in. When hot these bikes should start right up if you have a fully charged and healthy battery.2 - 80 LGs bought one new
Jim👍 1Comment
Most carbureted motorcycles like the throttle to be cracked a bit when started hot.-Mike
Previous: '68 Motoguzzi 600cc + '79 XS750SF 22k miles +'84 Honda V65👍 2Comment
Fuel injection and carbs are two different things! My FI motorcycles always started and ran great, with VERY little work needed. Carburetors need adjustments as they age. Multiple carbs, as on the XS1100, need to be "synchronized" almost yearly, or more often if you ride a lot. That is part of owning and old bike.Ray Matteis
Indeed. I have owned alot more carb machines, than not.Fuel injection and carbs are two different things! My FI motorcycles always started and ran great, with VERY little work needed. Carburetors need adjustments as they age. Multiple carbs, as on the XS1100, need to be "synchronized" almost yearly, or more often if you ride a lot. That is part of owning and old bike.Comment
For what its worth, my '79F also needs some jockeying of the throttle to restart after a heat soak restarting it hot. I may end up monkeying with the idle mixture a bit, this is with a fresh valve adjustment and good carb sync, stock jetting. For now I just chalk it up to the nuances of old bike ownership.'98 GSF1200S '81 GS850G
Past Yamahas: '79 XS1100F, '78 XS1100E, '76 XS500C👍 1Comment
Brakes are fixed, although they are pulsing with heavy braking. Gas tank is not. Very frustrated on that one... got the new rubber gasket in there... still weeping. I used copper sealing washers for the screws... perhaps I need a fuel resistant nylon. Its very hard to tell where the fuel is coming from. It may be coming from the area where the one lead attachs.👍 1Comment
