Left crankshaft oil seal
  • Appie
    • Nov 2024
    • 48
    • South Africa
    Good day gents!
    I’ve purchased a 1981 SH (second one). Mileage 47000km so relatively ‘young’ but in a neglected state. It’s arrived with me and straight off the bat on inspection I have
    - leaking camchain tensioner
    - leaking head gasket
    - leaking ?oil seal left crankcase. I haven’t opened the pickup cover yet to confirm but I do have oil dripping from that cover.
    So Im going to be going through the bike more thoroughly and certainly after a good clean but at the moment I only have time to do homework on this bike. So…
    Looking at crank seals left ( PN 9310132087) and right (PN 9310132088) they seem have the same dimensions. Problem is the left is unavailable.
    My question is can I use the right seal on the left? I have read some brilliant threads on this topic but I’m still none the wiser.
    Thanks to you all for your input 😎
    AT-205 RE-SEAL by ATP Automotive will stop the crankshaft seal leak. You can use that stuff until you resolve seal replacement. The stuff works as long as you’re using it. You add it to the oil.
      • 8963
      Here is a thread discussing the changing of the left side crankshaft seal....
      • Appie
        • Nov 2024
        • 48
        • South Africa
        Thanks Jetmechmarty! I never thought of an additive… We don’t have AT 205 here but we do have equivalents that I can use while I get to know this bike. Does it thicken the oil? I have a cb 650 and thinking of those pinhole oil valves through the block to the camshafts I get nervous.
        • Appie
          • Nov 2024
          • 48
          • South Africa
          https://xs11.club/forum/idle-talk-fo...-the-good-foot
          How did I miss this? Thank you bikerphil, back to the drawing board. I’ll post with feedback as soon as possible. I appreciate the help.
          You guys are legends!
            AT-205 will not thicken oil. It softens that rubber seal riding the crankshaft. It is the only product of its kind that I have used that actually works. All bets are off on anything else where I’m concerned.
            • speedlimit85
              • Jan 2017
              • 493
              • Gainesville, Fl.
              left has an outer diameter of 48mm right is 45
              80 G
              • Appie
                • Nov 2024
                • 48
                • South Africa
                Thanks for explaining that for me. And in thinking about a substitute I fully agree. Better to try and source something that has been tried and tested on this forum.
                I really don’t want to start a new topic ‘So I put this additive in my oil and….’ 🥴
                • Appie
                  • Nov 2024
                  • 48
                  • South Africa
                  Thanks speedlimit85! Not what I was hoping for but I do have other options now thanks to you guys. I was reading that the crankcase needs to be split to replace the original seal anyway which is beyond my pay grade at this stage.
                    I have yet to replace that seal, but I don’t believe splitting the cases is necessary, particularly with an aftermarket seal.
                      • 7844
                      The OEM seals are no longer available, so you CAN replace it without splitting the cases. The hard part is getting the old seal out as you will need to remove the lip that is "locked" in the case, but it is doable. Just be careful of the crank as you work the old seal out.
                        Perhaps a sheet metal screw and a Vise Grip plier is appropriate for that job?
                          Removal....
ID:	884924 Click image for larger version
ID:	884925 Click image for larger version
ID:	884926 Click image for larger version
                            Installation. Use a Viton seal.
ID:	884929 Click image for larger version
ID:	884930 Click image for larger version
ID:	884931 Click image for larger version
ID:	884932 Click image for larger version
