Shimmy
    • 2057
    • Ccitis
      • Jun 2023
      • 213
      Originally posted by LAB3
      There's a difference between static balance and dynamic balance. Static balance would be putting the tire and rim on a truing stand then using weights to balance it. Dynamic balance uses one of those newfangled machines that spins the tire up to speed and gives the operator the info they need to properly place the weights.
      With all that said, I don't bother with either method and use this stuff instead, it doesn't work for squat when it comes to punctures but does a great job at dynamically balancing as you ride. A LOT of shops are using it these days instead of other balance methods and for about $20 per tire a DIY guy like me can easily not give it second thought.
      https://ride-on.com/
      Interesting... and works on tubes?
      Shinkos were not my choice, PO had them on... and they were brand new so figured might as well. Pumped the tires up to 38, still have the vibration. Fork pressure is 10 on each side... I noticed I get the same vibration on hard braking. I can see the fork flexing back and forth from front to back when I hit the front brake hard. Strange. No notchiness in the steering bearings, bars fall to the side as they should. Might be replacing wheel and steering bearings next though to try and figure this out.
      • LenB
        • Nov 2020
        • 160
        • Winnipeg, Manitoba, Canada
        Ccitis - you're likely on top of this, but I'll just mention it anyway. Be sure your front axle clamp is tight to the base of the fork slider at the front and the gap is at the rear. This slight variation can really mess up your front end by throwing off your handling, possibly having and effect on gyroscopic precession at high speeds.
        1980 XS1100G (one owner-me)
        1984 Honda VF750S V45
        Owned - 1976 XS750D
        Owned - 1972 Honda CB750
        Owned - (unknown year) XS650
        • Ccitis
          • Jun 2023
          • 213
          I am trying to understand this... all advice is welcome. You are saying on the left side where the clamp is, there should be a gap?
            • 837
            I've used it on tube tires
            What LenB wrote has merit. Take a look at where the fork clamp meets the axle. The front edge of the clamp should sit directly in contact with bottom of the fork leg, there should be a gap left on the rear side of that. The front nut gets tightened down first and the rear nut after that.
              • 2101
              Torque specs for above mentioned: https://www.manualslib.com/manual/11...age=232#manual
              • Ccitis
                • Jun 2023
                • 213
                Got it. Will check and torque appropriately
                • LenB
                  • Nov 2020
                  • 160
                  Just like this....
                  Owned - 1976 XS750D
                  • Ccitis
                    • Jun 2023
                    • 213
                    Rechecked all the torque specs from top to bottom. All is in order, still getting the vibration. I am wondering about the tire itself. For now will just keep to slower speeds I suppose.
                      • 5073
                      Check the trailing arm bearings for torque spec. Be aware of the typo in the clymers.
                        • 2057
                        Clymer XS1100 manual Page 222. It's the torque spec for the swing arm pivot shaft bolts. It's listed as 47 foot pounds but should be 47 inch pounds.
                        • Ccitis
                          • Jun 2023
                          • 213
                          Will check today. Why do you think Swing arm pivot would impact front vibration?
                            • 7831
                            If the swing arm, in the rear, isn't doing what it's supposed to do, it can effect the front suspension.
                              • 2057
                              Wobble in the back - wobble in the front. The steering head acts like a hinge. This is why I suggested the balance of the rear tire. Very often overlooked.
                              • Ccitis
                                • Jun 2023
                                • 213
                                Checked everything in the back, all is good. Still shimmying. Heres a thought, the rear wheel says for tubeless tires. I don't have a tube in there. The front wheel says no such thing. I am running a tube in there. Could that be an issue at high speeds? Also, as an aside my XS is for sale. It is a very original example. I have 4 bikes, and I am having a kid soon. Sadly, the XS takes the hit here. If you are anyone wants to buy this bike I am in the Lower Mainland of BC, very close to the border. I would prefer it go to an enthusiast rather than someone that will wreck it, so willing to take offers from members here. https://vancouver.craigslist.org/rds...845582219.html
