Brake master cylinder diaphragm busing
  • aquamantx
    • Aug 2015
    • 198
    • Montgomery, TX
    Ok so cleaning up rear master. have the new kit for the innards but as we all know there is always something not available. Some guidance on the plate/busing that sits under the diaphragm. Super important, or just shape holder for the diaphragm? mines a little crusty and have cleaned. Should I just smooth out with a skim coat of jb weld or does someone have a source.
    81 LH in process
    09 vstar 1300
    only allowed 2
    • 1498
    No new parts available. This used unit can be cleaned up.
    • aquamantx
      • Aug 2015
      • 198
      • Montgomery, TX
      Appreciate the find. Mine was pretty crusty under the rubber but the rubber is still good. keep it for back up..
      81 LH in process
      09 vstar 1300
      only allowed 2
        • 697
        Remember, it's the rubber that does the sealing not the bushing. I'd just clean it up and use it as is.
          • 1952
          I'm with LAB3. I usually just hit them with a wire wheel and reuse them.
          I think JB Weld is asking for trouble being uneven and susceptible to chemicals.
          I'd pick POR15 if anything.
            • 7785
            I believe POR15 is solvent based. Zinc plate it.
              • 1952
              No solvent will dissolve POR15.
              Zinc plating is better if you can manage it.
                • 1812
                Just wanted to throw this out there Yambits : Master Cylinder Parts for Yamaha XS1100 1978-1980
                • aquamantx
                  • Aug 2015
                  • 198
                  • Montgomery, TX
                  Ok so master rebuilt with new kit but the darn thing doesn't want to return. Followed instructions and made sure seals went in the proper direction. Any thoughts? Silver lining, I'm getting decent in removing a rear master cylinder.
                  81 LH in process
                  09 vstar 1300
                  only allowed 2
                    • 8672
                    The "cupped" side of the seals face towards the brake hose, and the inner seal needs to go over the inner shoulder as shown in the following pic...
                    Click image for larger version  Name:	IMG_20250425_223832.jpg Views:	0 Size:	110.8 KB ID:	884389
                    • aquamantx
                      • Aug 2015
                      • 198
                      • Montgomery, TX
                      Mine are facing that way. Spindle is a little different. spool sides in ok but sticks on return. I'm going to see what original seals do again,
                      81 LH in process
                      09 vstar 1300
                      only allowed 2
                        • 8672
                        Hopefully when you assembled it, you used either clean brake fluid or red rubber grease, otherwise the plunger may stick.
                        • aquamantx
                          • Aug 2015
                          • 198
                          • Montgomery, TX
                          Used red rubber grease.. Old seal has plunger running smooth. I will have to see if it leaks.
                          81 LH in process
                          09 vstar 1300
                          only allowed 2
                            • 7785
                            I recently had a failed master cylinder rebuild. I ordered a 2nd kit and did it again. It works fine. I can’t say for sure what went wrong, but it certainly wasn’t my first rodeo.
                              • 1498
                              I usually hone them lightly and wash the bore before rebuilding.
Name:	Opera Snapshot_2024-12-21_044549_dealer.klsupply.com.png
