Ok so cleaning up rear master. have the new kit for the innards but as we all know there is always something not available. Some guidance on the plate/busing that sits under the diaphragm. Super important, or just shape holder for the diaphragm? mines a little crusty and have cleaned. Should I just smooth out with a skim coat of jb weld or does someone have a source.
Brake master cylinder diaphragm busing
No new parts available. This used unit can be cleaned up.
https://www.ebay.com/itm/11622730739...Bk9SR4SC5J6mZQ
Remember, it's the rubber that does the sealing not the bushing. I'd just clean it up and use it as is.1980 XS1100G
Intelligent people discuss ideas, average people discuss events, petty people discuss other people.Comment
I'm with LAB3. I usually just hit them with a wire wheel and reuse them.
I think JB Weld is asking for trouble being uneven and susceptible to chemicals.
I'd pick POR15 if anything.Last edited by Radioguylogs; 02-23-2025, 10:45 PM.-Mike
Previous: '68 Motoguzzi 600cc + '79 XS750SF 22k miles +'84 Honda V65Comment
Just wanted to throw this out there Yambits : Master Cylinder Parts for Yamaha XS1100 1978-19802 - 80 LGs bought one new
JimComment
Ok so master rebuilt with new kit but the darn thing doesn't want to return. Followed instructions and made sure seals went in the proper direction. Any thoughts? Silver lining, I'm getting decent in removing a rear master cylinder.81 LH in process
09 vstar 1300
only allowed 2Comment
Hopefully when you assembled it, you used either clean brake fluid or red rubber grease, otherwise the plunger may stick.2H7 (79) owned since '89
☮Comment
I recently had a failed master cylinder rebuild. I ordered a 2nd kit and did it again. It works fine. I can’t say for sure what went wrong, but it certainly wasn’t my first rodeo.Marty (in Mississippi)
XS650E👍 1Comment
