Digital XS11 Ignition
That one has been linked here before. Here's the manufacturer link:
https://www.elektronik-sachse.de/sho...ha-xs1100.html1980 XS1100G
I identify as a man but according to the label on a package of Stauffers Baked Lasagne I'm actually a family of four!
Anyone fitted one up, and if so, what benefits have you experienced?78 XS1100E touring
78 XS1100E stock
80 XS1100LG Midnight Special
83 XV920MK Midnight Special
83 XJ750MK Midnight Special
83 RX50 Special
97 FLHR
My problem with the looks of that is wire flex. We KNOW why the old pickup coils failed, and the wire used does not look like the "flexible wire" needed to keep things from breaking.
I may need to look into building one of my own, that would meet MY specs for reliability.Ray Matteis
Originally posted by DiverRay View PostMy problem with the looks of that is wire flex. We KNOW why the old pickup coils failed, and the wire used does not look like the "flexible wire" needed to keep things from breaking.
This system basically eliminates the manual vacuum advance. No moving parts so no wires moving or flexing. Z18-14-en.pdf2 - 80 LGs bought one new
Just wanted to add a note from the site that sells it.
Digital ignition system for Yamaha XS1100, replacement for the original electronic ignition and advance unit. The vacuum advance won't be used any longer.
Most models have a 15 mm shaft diameter. The 2H7 and 2H9 models have a 14 mm shaft, so if you have a 2H7 or 2H9 make sure you select 14 mm shaft version.
Elektronik Sachse MHP - Digital Ignition ZDG 3.23 for Yamaha XS11002 - 80 LGs bought one new
