Niche Brake Rotors
  • Peanutbutter Nma
    • Jul 2024
    • 45
    • Pennsylvania
    One thing I notice that is wrong is the silver clips have a curved edge that should be flat sitting flush with the caliper bracket. It is contacting the corner of the pad. I would either use the originals if you have them or hammer that curve flat so it doesn't bind with the corner of the pad.
    Those are the originals, the pictures where the pad isn't in the bracket are the ones with the new shims. That picture is a bit deceptive, but that's actually a feature of the shims. The sit flush but have a chamfered shoulder. You can make it out here: https://www.mikesxs.net/yamaha-xs650...0/XS1100E/1978
    As far as I can tell, the new and old shims are nearly identical except being too wide for the pads. I took measurements all over with my calipers (digital measuring tool, not brakes) and that's the only angle they're different in.
    1978 XS1100E - "Bessie"
    1978 XS1100E - "Pearl"
    Previous bikes:
    2012 Yamaha YZF-R6
    2015 Yamaha MT-09 - "Amber"
      • 8061
      FWIW, MikesXS is under the Revival Parts Group umbrella. https://www.revivalparts.com/
      The link has the list of who they own.
        • 2004
        Filing in these area lightly helped in the installation of the rear pads. They should be snug but they can still move back and forth under pressure.
          • 8889
          I see that now, the triangular corner. Sorry for the confusion.
          • Fairlyodd45
            • Aug 2023
            • 28
            • Escondido, CA
            I like mine. Several thousand miles with no issues. However, I did have to relieve the pads in the back to clear the rotor mount bolts. Must be thicker material than a stock rotor. The positive: Brutally excellent braking and I really use them trying to stop a fully laden sidecar rig.
            Click image for larger version  Name:	DSCN2391.JPG Views:	163 Size:	205.3 KB ID:	881557 Click image for larger version  Name:	DSCN2226.JPG Views:	159 Size:	158.1 KB ID:	881558 Click image for larger version  Name:	DSCN2246.JPG Views:	160 Size:	188.0 KB ID:	881559 Click image for larger version  Name:	DSCN2251.JPG Views:	161 Size:	140.8 KB ID:	881560 Click image for larger version  Name:	DSCN2245.JPG Views:	156 Size:	141.8 KB ID:	881561
            I purchased the exact set of rotors from NICHE for the front of my '79 F and once I mounted my new calipers the rivets that attach the braking surface to the rotor hub jammed up on the inboard brake pads. There was an overlap of at least 1/2" on each inboard pad. I tried everything I could think of short of grinding down the rivets to make these rotors clear the brake pads without any luck. I have no idea what went wrong, but they clearly did not fit my '79 F. Any thoughts ? This is directly from Amazon: Compatible with OEM Part Numbers Yamaha 2H7-25831-00-00, 5G9-25831-10-00, 5G2-25831-10-00 Compatible with Yamaha 1978-1980 XS1100, 1980-1981 XS1100L, 1978-1981 SR500, 1981-1983 XJ550R, 1980-1983 XJ650, 1981 XJ650L, 1982-1983 XJ750, 1981-1983 XJ750R Now either I am a complete idiot or they sold me the wrong rotors packaged as the correct ones, but I can guarantee you these did not fit at all. U shipped them back for a full refund. If any of you know where I can purchase a set of a direct fit upgraded set of front rotors for my '79 F please hook me up. Thanks
            • Fairlyodd45
              • Aug 2023
              • 28
              • Escondido, CA
              I did find a set of EBC rotors that are supposed to be an exact fit for my '79 F from Dennis Kirk. Anyone have any luck with these? Thanks.
                • 2004
                Fo45, while I did not have fitment issues, I did find that they warped after about 5 thousand miles but worked good up to that point. I ended up installing EBC units which are much higher quality rotors. VDM2024 is the correct part number.
                Click image for larger version  Name:	DSCN4299.jpg Views:	0 Size:	174.1 KB ID:	884509
                  • 2004
                  I did mention the filing of the pad. Once you do that, they fit fine. But I would not recommend them because they warp to easily.
Name:	File the back pad. Not the rivet..jpg
                  • Fairlyodd45
                    • Aug 2023
                    • 28
                    • Escondido, CA
                    Yeah you do get what you pay for, especially with NICHE, so lesson learned. I wasn't willing to file down the inboard pads just to make the rotors fit, so I sent them back. I will pick up a set of EBC rotors and hopefully I will have better luck. Thanks again brother!
                    • Ccitis
                      • Jun 2023
                      • 205
                      Man those EBC rotors are pricey. I am chasing a fork vibration, I am hoping it is the Shinko tires... hoping some BT46s fix it. Could be head bearings I suppose (no play), or rotors I guess... happens at higher speeds, also on brake application though. We shall see.
                      • Mathh
                        • Nov 2006
                        • 696
                        • Beek, Netherlands
                        I know the EBC's are pricey but me and a pal of mine have been fitting them to all of our Kawasaki Z1/900's and Z1300's we owned. Even the oversized kits they sold in the past were spot-on as well.
                        Here's a pic from one of my Z1A's...
                        MV Agusta Brutale 910R '06.
                        Yamaha MT-09 Tracer '15 grey.
                          • 2004
                          You can't go wrong with EBC rotors. Very high quality. I also run them on my Kwackers.
ID:	889811 Click image for larger version
                            • 8889
                            Just ordered a pair of the VDM2024. So tired of dealing with warped rotors. Hope these are gonna last.
                              • 812
                              I've yet to try this guy out but for $55 a rotor he regrinds them up to specs. https://truedisk.net/
                                • 2096
                                I used his service when I refurbished my '89 Moto Guzzi California III disc rotors which are Ductile iron and oxidize just sitting in a dry garage. He did a great job.
