Fuel gauge problem
  • CBX1000
    • Sep 2024
    • 15
    • Wakefield New Zealand
    Fuel gauge problem
    Hi all- new to the forum & also just acquired a '79 1100E down here in New Zealand.
    Bike had been standing for around 4 years unused- basically a non runner. I have got it up & running & the first thing that jumped out at me was the fuel gauge which doesn't work. I checked out the tank sender unit with a multimeter & that is all good. Then checked the wiring up to the gauge itself which is also all good. Next obvious check was the gauge itself; stripped down the tacho unit & found that a part of the fuel gauge has become dislocated- there is also a broken strand which attaches to the coiled part. Is anyone able to guide me as to how the loose part fits onto the gauge- I'm struggling to work this out. To me it looks like there could be something missing as well- I suspect that the tacho unit has been opened prior to my ownership of the bike. Photos attached.
    Any help much appreciated
    Dave H
  • jkorn
    • May 2003
    • 187
    • Wickenburg AZ
    Sorry, I can’t. But I’m extremely impressed with your trouble shooting expertise . Jeff
    Jeff Korn
    Original Owner 79XS1100 E
    • CBX1000
      • Sep 2024
      • 15
      Thanks Jeff- I've been repairing & restoring CBX1000's for quite a few years & doing that sure has paved the way for this adventure of XS1100 ownership
        • 7712
        Give me a day or two and I should have some pictures for you. I have guages here, just need the time to get one apart to take a photo or two.
          • 8753
          Here's some pics of one I repaired a while back...
          • CBX1000
            • Sep 2024
            • 15
            Now that is really helpful- many, many thanks. Clearly my unit has also snapped the tempered piece of metal like yours did- I will attempt to rejoin with solder like you've done. I just hope that I can solder the very fine strand of wire back to the wound section again. What happens to the other end of the tempered piece- does it rest against something or just stand free?
            • CBX1000
              • Sep 2024
              • 15
              Thanks Ray- if I am unable to repair mine I may well have to ask you if you're willing to sell me either a working fuel gauge or perhaps an entire tacho
              Dave H
                • 8753
                Couple more pics...
                Click image for larger version  Name:	IMG_20240906_084900.jpg Views:	0 Size:	121.0 KB ID:	881475
                Click image for larger version  Name:	IMG_20240906_084943.jpg Views:	0 Size:	112.5 KB ID:	881476
                The other closed end of the bi-metal just floats. One leg has been soldered to repair and the other has a solid round piece spot welded to it that operates the needle itself.
                ​​​​​​ Click image for larger version
                  • 7712
                  Dave, If you do need it, send me a PM. I was trying to put together a '78 I've had for a while, but may go for a different look. It will not be the first time I've send XS1100 parts to NZ!
                  • Ccitis
                    • Jun 2023
                    • 170
                    Welcome to the forum. I totally understand wanting a working fuel gauge, I got mine going... BUT they are notoriously off on their readings... Mine goes down very fast, even when I have plenty of fuel left. Trip Odometer is definitely the best way to track your fuel prior to hitting res. Good luck, enjoy the bike.
                    • CBX1000
                      • Sep 2024
                      • 15
                      [QUOTE=bikerphil;n881474]Couple more pics...
                      ​​​​​​Thanks a million Phil- just what I needed to see
                      Dave
                      • CBX1000
                        • Sep 2024
                        • 15
                        Thanks bud- glad to be here. Agreed- the trip meter is the best way to keep tabs of the fuel situation however me being me I like everything to be operational...I'm just an old fart now
                        • CBX1000
                          • Sep 2024
                          • 15
                          Good to know Ray; I've scheduled fuel gauge surgery for this weekend & will report back once the patient is in the recovery ward
                            • 8753
                            You can test the gauge on the bench after repairing by simply touching a 9V battery to the posts, and you will see the needle slowly rise if it is working correctly. The voltage regulator in the wiring harness on the back of the tach is 7VDC. They are also known to go bad.
                            • Ccitis
                              • Jun 2023
                              • 170
                              I totally get it. I am the same way... I got mine back up and running. But just don't be surprised when it is pessimistic. Enjoy the project!
