Weeping Sight Glass
  • Ccitis
    • Jun 2023
    • 177
    Weeping Sight Glass
    Noticed the sight glass is weeping a bit of oil on the bottom. Not a big deal... anyone else use silicone or something to stop it? Or just live with it?
    • 7766
    There was a replacement available,2H7-15361-00-00 GAUGE, LEVEL. Not sure if it's still around, though. This is the early part number, and it probably changed.
      • 8800
      Nothing you can do really to stop it from leaking without removing the clutch cover. New one is less than $10 at MikesXS. You won't even have to drain the oil if you do the repair with the bike on the side stand.
      Click on image...
      Click image for larger version  Name:	Screenshot_20240808-180831.png Views:	0 Size:	175.3 KB ID:	881252
        • 1821
        Looks like you can heat up the cover and press it out & in with a proper socket. I like these for quick checking oil in the summer but they get cloudy and unreadable in the winter. I have to use a heat gun to clear the water vapor away just to check my oil when it gets really cold out.
          • 774
          Has anyone come across a better way to check their oil level than the sight glass? It's a real PITA trying to get mine into the center stand while fully loaded with gear and pulling a trailer!
          Deebs, there can't be much room on your sidecar rig to get down there for a look! Any suggestions?
            • 1821
            LAB3, very observant. I have to use an Ocean State Job Lot mirror and flashlight to see down there.
              • 774
              Thanks! Something like that shouldn't be too hard to come by.
              • Ccitis
                • Jun 2023
                • 177
                I am a big fan of the good old fashioned dipstick, but they are few and far between on motorcycles! I didn't realize it was so easy to replace the sight glass. I will add it to the winter maintenance list. Not a big deal pulling that cover, re gasketing, then putting a new glass in.
                On another note, probably a whole different thread... but I assume it is normal for these older air cooled bikes to use some oil? I have no smoke or blowby... no sign of oil loss, but I do have to top up every couple rides... a couple glugs of oil to get it where it should be. My old BMW oilhead was the same.
                  • 774
                  My oil consumption varies. Out on the interstate maintaining a constant speed I'll use maybe 8 oz on a 500 mile trip. On the other hand if I'm making short runs of say 10-15 miles without the engine warming up or running the revs hard back and forth in the Twisties I might use an entire quart in that same 500 miles.
                  • Ccitis
                    • Jun 2023
                    • 177
                    Anyone know the volume before full and low on the sight glass?
                      • 1821
                      Due to residual oil of possible different volumes after draining, it's always best to use the sight glass for accurate levels. In some cases it's worse to put too much oil in.
Name:	oil window level.jpg
                        • 5062
                        It is about 1/2 quart difference I think.
