Tool Kit
Tool Kit
"Project XS11"
For Sale Here.Tags: None -
Thanks Ccitis. Only one of the kits had the shock adjusting tool that you have identified. A couple of the tool kits have the item on the right. It's a mystery to me too.Bob's Bikes:
"Project XS11"
For Sale Here.Comment
Socer4m has purpose close. That hook came in original tool kit for Specials. Right side swing-arm has protruding piece for it to hook on. Also the original tool kit came with a small diameter steel cable that hooked on cable and then hooked on upper frame rail making rear brake caliper easier to remove
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
BTW, interesting enough, my bought new 81 XS1100 Venturer came with the hook and cable in the tool kit. Thought that was interesting as the Venturer basicly is a Standard and not needed for rear caliper removal. My Venturer tool kit is as it came new and never has been used.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Thanks Guys,
I found that wire hook came with the special models...
but is not shown with the standard models that came with the cable and special tool for removing the rear axle.
So, at least I know it goes in the special tool kit, But what I haven't figured out is what the wire hook is used for. Not that I'll ever use it, just curious.
Any Guesses?
This Yamaha 3H3-2814A-00-00 WIRE, HOOK fits the following models and components:
Yamaha Motorcycle 1980 XS1100LG SIDE COVER
Yamaha Motorcycle 1981 XS1100SH SIDE COVER
Yamaha Motorcycle 1980 XS1100SG SIDE COVER
Yamaha Motorcycle 1979 XS1100SF SIDE COVER - BATTERY BOX
Yamaha Motorcycle 1981 XS850LH Side Cover - Tool
Yamaha Motorcycle 1982 XJ1100J Side Cover - Tool
Yamaha Motorcycle 1981 XS1100H Side Cover - Tool
Yamaha Motorcycle 1980 XS850SG Side Cover - Tool
Yamaha Motorcycle 1980 XS850G Side Cover - Tool
Yamaha Motorcycle 1981 XS1100LH Side Cover - Tool
Yamaha Motorcycle 1981 XS850H Side Cover - Tool
Yamaha Motorcycle 1981 XS850SH Side Cover - Tool
Yamaha Motorcycle 1980 XS850LG Side Cover - Tool
"Project XS11"
I have the hook tool in mmy SG tool kit in the plastic seat storage. I will have to see what it is used for in my shop manual.1980 XS1100 SG
1997 Jeep Cherokee 4.5"lift installedComment
The shock adjustment spanner can also be used on the two ring type nuts on the steering stem.1980 XS1100G
Intelligent people discuss ideas, average people discuss events, petty people discuss other people.Comment
Well, those engineers thought of everything!
And here I've been using a shoestring all along!
Thanks Deebs,
Another mystery solved!Bob's Bikes:
"Project XS11"
