1979 special edition - Fork Seals
  • OldGreyBeast
    • Mar 2024
    • 100
    • Florence, AL, USA
    I ran into quite a few issues with fork seals on this bike. I tried 2 different aftermarket kits (Bike Master and the one Old Bike Barn sells) and neither would work. They were too thin so I 3d printed a spacer to make them sit flush, but still every time I would have to press them in with a hydraulic press to try to get it to seat. This resulted in stripping rubber off all around the sides. I know these are meant to be tight but if it's tearing rubber off then it's obviously too tight.
    After poking around for a while I found a pair of NOS Yamaha seals. They are almost exactly the height of the aftermarket seal + my printed spacer and are slightly smaller in diameter. The 37x49.8/9.5 size listed many places around the Internet is NOT correct for the 1979 special edition. The correct size is 37x48x12.5. Wanted to make a thread about it to save anyone else building one of these the time and money.
    Difference in thickness, Yamaha on the left Bike Master on the right
    Thickness with my spacer
    Diameter difference, Bike Master on the left, Yamaha on the right
    • 8891
    You may have seals for a Standard, which are a different size than the Specials.
    The correct size for the Special is 37x48x10.5
    The Standard uses 37X49X8
      Uhmmm......(O_o)
      But whut method are you using to assemble/install everyhting? ( ´・_・`)
      I mean there's the "Faktory Method" which usually cuts the FARK outta the seal cuz of a razor sharp edge... (Ő︵Ő)
      and then there's THIS one-
      Me? (O_o)7
      I used the latter one to replace the seals on my standard. (^_^)
      But that wuz even befOaR I wuz a member here. 'Round 2005 or there-a-boutz. (ー_ーゞ)
        • 2010
        This is an XS11 Special only fork seal part #3J6-23145-00-00
          • 2010
          https://www.ebay.com/itm/30330494187...Bk9SR4ayn-iKZA
            XS 11 Standard models us KYB front forks and XS 11 Special models use Shoiwa forks. As previously stated, fork seals sizes are different for each of the two models.
